the AI Hardware Partner
Toggle Nav
Loading...
Crazyflie 2.0 - Spare 240mAh LiPo battery
Small high performance spare battery for the Crazyflie 2,bitcraze, bitcraze.io,crazyfly, crazieflie, crazieflie, crazy flie, crazie fly, crazy fly, drone
$5.50
Out of stock
Small high performance spare battery for the Crazyflie 2.0
Operating Temperature: 0 ~35°C (Charging) / -20~60°C (Discharging)
Connector: Molex 51005-2P (Pin 1 positive)
Electrical specification
Capacity: 240mAh
Nominal voltage: 3.7 V (1 Cell)
Discharge: 15C
Charge: 2C
Mechanical specification:
Weight: 7.1g
Size (WxHxD): 20x7x30mm
Caution
Using the battery under direct sunlight may cause overheating, which could result in invalidation or fire. Battery should be charged with proper charger, in compliance with correct operation instruction.
Bitcraze
Wiki
Forum
Tech Support
If you have any further question for technical support, please contact [email protected]
Dimensions 0mm x0mm x0mm
Weight G.W 7g
Battery Lithium Cells / Batteries loose (bulk) UN3480-PI965
240mAh LiPo battery 1
HSCODE 8507600090
ROHS 1
