the AI Hardware Partner
Toggle Nav
Loading...
RF Explorer 433M
RF Explorer is a handheld digital spectrum analyzer, aimed to provide a very affordable tool for work in all ISM popular frequency bands
$99.00
Out of stock
RF Explorer is a handheld digital spectrum analyzer, aimed to provide a very affordable tool for work in all ISM popular frequency bands. It is based on a highly integrated frequency synthesizer which offers high performance, compact size, low consumption and low-cost.
It has been designed to be used equally well outdoor and indoor, and can be connected to a Windows PC using standard mini-USB for additional features and higher display resolution.
We also prepared a nice EVA case for RF Explorer, check it out here
Feature
  • Pocket size and light weight
  • Solid aluminum metal case
  • Spectrum Analyzer mode with Peak Max and Hold, Normal, Overwrite and Averaging modes
  • Integrated RF Signal Generator
  • Lifetime free firmware upgrades available, open to community requested features
  • High capacity Lipo for 16hs+ of continuous run, rechargeable by USB
  • Windows PC client Open Source
  • Can be extended with internal Expansion Modules for additional band and functionality
  • Frequency band:430-440 MHz
  • Frequency span: 112 KHz-10 MHz(enhanced to 30 MHz if an Expansion Module is connected)
  • Graphics LCD 128x64 pixels, great visibility outdoors
  • PC Windows client supports Windows XP/Vista/Win7 both 32 and 64bits
  • Backlight for great indoor visibility
  • Standard SMA 50 ohms connector, a matching antenna is included
  • Amplitude resolution: 0.5dBm
  • Dynamic range: -115dBm to 0dBm
  • Absolute Max input power: +5dBm
  • Average noise level (typical): -110dBm
  • RF Generator amplitude: 0dBm to 20dBm
  • Frequency stability and accuracy (typical): +-10ppm
  • Amplitude stability and accuracy (typical): +-3dBm
  • Frequency resolution: 1Khz
  • Resolution bandwidth (RBW): automatic 2.6Khz to 80Khz
  • Weight: 185g
  • Size: 113x70x25 mm
Techsupport
This product is designed by RF-Explorer,
  • For more info and to get started with your RF Explorer, visit the start page.
  • For questions and support, please visit https://support.rf-explorer.com.
  • For the software for RF Explorer series, please click the following logo for more information:
If you'd like to buy or change the RF Explorer Battery, please click here.
Dimensions 0mm x0mm x0mm
Weight G.W 257g
Battery Lithium Cells / Batteries contained in equipment UN3481 - PI967
RF Explorer - 433M 1
HSCODE 9030401000
USHSCODE 8517180050
UPC 841454104001
EUHSCODE 9030900000
COO CHINA
RoHS 1
Documentations
Documents
