the AI Hardware Partner
Toggle Nav
Loading...
Sick Of Beige Basic Case v1 (DP9056)
Rating:
100 % of 100
A clear laser-cut acrylic project case kit that fits DP9056 golden-rectangle PCBs (90mmx56mm)
$3.00
Out of stock
A clear laser-cut acrylic project case kit that fits DP9056 golden-rectangle PCBs (90mmx56mm). Protect your project from electrical shorts and fingers, but keep it accessible for hacking and showing off. Sick of Beige basic case v1 is designed to be simple, cheap, and easy to assemble. The project PCB is sandwiched between two laser cut acrylic sheets, and the whole assembly is held together with aluminum screws and standoffs.
Sick of Beige PCB templates and clear enclosures make it super easy to design your project for a case. Drop a standard PCB footprint on your schematic, and then route on the board template. The board shape, size, limitations, and many connector placements are already taken care of.
This case fits DP9056 (90mmx56mm PCB size) compatible PCBs.
If you encounter any problems when using this product, here is the forum from which you can get the technical support.
Dimensions 100mm x65mm x10.5mm
Weight G.W 45g
Battery Exclude
HSCODE
  1. Product Quality
    100%
    By
1 Item
Show per page
