LCD module spec
Is the LCD module proprietary? If no, is it possible to get the spec?
thanks
here is the Specifications of this LCD
FGD280A3701.rar (256 KB)
and datasheet will be upload soon
Here is the datasheet for ST7781 controller of this LCD ~
Doc3 ST7781 DATASHEET.rar (1.02 MB)
And below is the Initial flow of this LCD :
void initial_ST7781(void)
               //------------------------------------Display Control Setting-------------------------------------------//
	 LCD_SET_REG_MAIN(0x0001, 0x0100); //Output Direct
	 LCD_SET_REG_MAIN(0x0002, 0x0700); / ne Inversion
	 LCD_SET_REG_MAIN(0x0003, 0x1030); //Entry Mode (65K, BGR)
	 LCD_SET_REG_MAIN(0x0007, 0x0121); //Display Control1
	 LCD_SET_REG_MAIN(0x0008, 0x0302); // Porch Setting
	 LCD_SET_REG_MAIN(0x0009, 0x0200); //Scan Cycle
	 LCD_SET_REG_MAIN(0x000A, 0x0000); //FMARK off
	  //-----------------------------------End Display Control setting-----------------------------------------//
	  //-------------------------------- Power Control Registers Initial --------------------------------------//
	 LCD_SET_REG_MAIN(0x0010, 0x0790); //Power Control1
	 LCD_SET_REG_MAIN(0x0011, 0x0005); //Power Control2
	 LCD_SET_REG_MAIN(0x0012, 0x0000); //Power Control3
	 LCD_SET_REG_MAIN(0x0013, 0x0000); //Power Control4
	 //---------------------------------End Power Control Registers Initial -------------------------------//
	 LCD_DelayMs (100); //Delay 100ms
	 //--------------------------------- Power Supply Startup 1 Setting------------------------------------//
	 LCD_SET_REG_MAIN(0x0010, 0x12b0); //Power Control1
	 LCD_DelayMs (50); //Delay 50ms
	 LCD_SET_REG_MAIN(0x0011, 0x0007); //Power Control2
	 //--------------------------------- End Power Supply Startup 1 Setting------------------------------//
	  //--------------------------------- Power Supply Startup 2 Setting------------------------------------//
	 LCD_SET_REG_MAIN(0x0012, 0x008c); //Power Control3
	 LCD_SET_REG_MAIN(0x0013, 0x1600); //Power Control4    //1700
	 LCD_SET_REG_MAIN(0x0029, 0x002e); / COMH setting    2a-2e   //22
	 //--------------------------------- End Power Supply Startup 2 Setting------------------------------//
	 //-------------------------------------Gamma Cluster Setting-------------------------------------------//
	 LCD_SET_REG_MAIN(0x0030, 0x0000);
	 LCD_SET_REG_MAIN(0x0031, 0x0505);
	 LCD_SET_REG_MAIN(0x0032, 0x0205);
	 LCD_SET_REG_MAIN(0x0035, 0x0206);
	 LCD_SET_REG_MAIN(0x0036, 0x0408);
	 LCD_SET_REG_MAIN(0x0037, 0x0000);
	 LCD_SET_REG_MAIN(0x0038, 0x0504);
	 LCD_SET_REG_MAIN(0x0039, 0x0206);
	 LCD_SET_REG_MAIN(0x003c, 0x0206);
	 LCD_SET_REG_MAIN(0x003d, 0x0408);
	 //--------------------------------------End Gamma Setting--------------------------------------------//
	 //----------------------------------Display Windows 240 X 320----------------------------------------//
	 LCD_SET_REG_MAIN(0x0050, 0x0000); // Horizontal Address Start Position
	 LCD_SET_REG_MAIN(0x0051, 0x00ef); // Horizontal Address End Position
	 LCD_SET_REG_MAIN(0x0052, 0x0000); / ertical Address Start Position
	 LCD_SET_REG_MAIN(0x0053, 0x013f); // Vertical Address End Position
	  //----------------------------------End Display Windows 240 X 320----------------------------------//
	  //-------------------------------------Frame Rate Setting------------------------------------------//
	 LCD_SET_REG_MAIN(0x0060, 0xa700); //Gate scan control
	 LCD_SET_REG_MAIN(0x0061, 0x0001); / n-display Area setting
	 LCD_SET_REG_MAIN(0x0090, 0x0033); //RTNI setting
	 //---------------------------------------END Frame Rate setting------------------------------------//
	 LCD_SET_REG_MAIN(0x0009, 0x0000); //Scan Cycle
	 LCD_SET_REG_MAIN(0x0007, 0x0133); //Display Control1
void ST7781CPT24_Enterstandby(void)
LCD_SET_REG_MAIN(0x0007,0x0131);
                    Delayms(50);                 //delay 50ms
                    LCD_SET_REG_MAIN(0x0007,0x0020);
                    LCD_SET_REG_MAIN(0x0010,0x0082);
void ST7781CPT24_Exitstandby(void)
LCD_SET_REG_MAIN(0x0011,0x0005);
                    LCD_SET_REG_MAIN(0x0010,0x12b0);
		LCD_SET_REG_MAIN(0x0011,0x0007);
		LCD_SET_REG_MAIN(0x0012,0x008c);
		LCD_SET_REG_MAIN(0x0013,0x1700);
                    LCD_SET_REG_MAIN(0x0007,0x0133);
