seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      0.5 Inch OLED display Arduino shield
      SKU 308020004
      $15.00
      13 Available
      $15.00/1pcs+
      $14.80/10pcs+
      ADD TO CART
      OCELL is a 0.5 inch OLED module designed as a  Arduino shield and also available for other  micro controllers . It is the smallest Arduino display module you can find so far.
      You could connect it to Ardunio micro directly without doing any PCB layout and also available for other controllers . It is a good choice for a DIYer to make a project which need a tiny COOL OLED display.
      • The smallest size in all Arduino display modules so far.
      • Very high contrast and brightness.
      • Very low power consumption
      • No backlight required
      • Supported by U8glib library
      High light
      These OLED displays are small, only about 0.5"diameter, but very readable due to the high contrast (450cd/m^2 brightness). This display is made of 60x32 individual white OLED pixels, each one is turned on or off by the controller chip. Because the display makes its own light, no backlight is required. This reduces the power required to run the OLED and is why the display has such high contrast and very low power consumption.
      • PCB dimensions: 17.8mm X 15.5mm
      • Screen size: 0.5 (inch) W. H: 15.30x10.20 mm
      • Color: Monochrome (white)
      • OLED  type: PM -OLED
      • OLED driver: LD7032
      • Pixels : 60 x 32
      • Contrast: 2000: 1
      • Communication: SPI, I2C
      Note
      • 1 pc OCELL includes: 1x module PCB , 1x OLED display , 1x10 pins header
      • Does not include: Arduino
      Documents
      Technical Details
      Dimensions80mm x 100mm x 3mm
      WeightG.W 6g
      BatteryExclude
      Reviews
      Questions and Answers
      SUBMIT
      1
      Hello,Does each oled have a unique address for I2C communication, or do they all have the same address?
      on Sep 06,2017
      Replyupvote ()
      We do not have this modul on our hand,but it seems only one OLED.Do you have two of this module?
      on Sep 07,2017 13:53 PM
      Replyupvote ()
      I do not have one yet, however i'm interested in purchasing multiple ones. I just wanted to be sure that using I2C protocol i can address all of these modules independently (If they have unique addresses).
      on Sep 07,2017 16:09 PM
      Replyupvote ()
      Yes,you can config the I2C address by ID0~DI2 pins.
      on Sep 08,2017 13:25 PM
      Replyupvote ()
      Reply
      0
      dot pitch, power rating, third dimension, weiht, viewing angle?
      on Nov 08,2016
      Replyupvote ()
      hi , please refer to http://www.seeedstudio.com/document/pdf/0.5OLED%20SPEC.pdf
      on Jan 15,2018 10:16 AM
      Replyupvote ()
      Reply
        View History
        SKU 308020004
        $15.00
        13 Available
        ADD TO CART
        $15.00/1pcs+
        $14.80/10pcs+
        • Best-sellers
        • Description
        • Technical Details
        • Reviews
        • Questions and Answers
        • View History
        SUBMIT
        Invalid email address.
