0.8 Inch 16 Segment LED Blue - Common Cathode
  • 0.8 Inch 16 Segment LED Blue - Common Cathode
SKU 104990133
  • We are sorry the description is wrong, Please pay attention this is Common Cathode
  • This is a 16 segment common cathode LED and is blue
    $1.95
    DISCONTINUED
    This is a 16 segment common cathode LED and is blue. The advantage of 16 segment is that you can not only display 1234567890, but also ABCDEFGHIJKLM.
    It is compatible with bread board and can work with Arduino by adding some current limiting resistors. So, it Suitable for people who is newbie of electronic.
    Note: It just a segment LED without control chip.
    High Light
    low current
    low-voltage
    low energy
    Longevity
    IC-compatible
    0.80 inch
    common port: 11
    size: 20.0 x 27.7 x 8.5mm
    Colors: blue
    surface colors: Black
    Working temperature: -20~60°C
    Mechanical Outline:
    Unspecified Tolerances is: X±0.2
    Absolute Maximum Ratings
    Parameter
    Symbol
    Maximum Rating
    Unit
    Power Dissipation
    Pd
    mW
    Peak Forward Current
    Ifp
    150
    mA
    Continuous Forward Current
    Ifm
    20
    mA
    Reverse Voltage
    VR
    5
    V
    Operating Temperature Range
               topr
    -40 → +85
    Storage Temperature Range
    Tstg
     -40 → +100
    Static Voltage
    Var
    V
    * Lead Sodering Temperature:260℃  for 3 seconds
    * For  operation above 25℃,  The Ifm Ifp & Pd must be derated, the Curent derating is –0.36mA/℃ for  DC drive and  -0.86mA/℃ for Pulse drive, the power dissipation is  -0.75mW/℃. The product working current must not more than the 60% of the Ifm or Ifp according to the working temperature.
    Optical-Electrical Characteristic
    Parameter
    Test CONDITING
    Symbol
    Min
    Type
    Max
    Unit
    Luminous Intensity
    IF=10mA
    Iv
    65.5
    68.2
    72.5
    Mcd
    Forward Voltage
    IF=10mA
    VF
    3.14
    V
    REVERSE Current
    VR = 5V
    IR
    20
    uA
    Peak Wavelength
    IF=10mA
    155.7
    461.1
    462.9
    463.3
    nm
    Spectral Bandwidth
    IF=10mA
    △λ
    40
    nm
    View Angle
    IF=10mA
    2θ1/2
    Deg.
    Storage & Soldering Condions:
    Store with care. Storing the units in bad condition will cause the reflector sheet and decrease it’s adhesive  power. Storage  the  products  under  the condition :temperature ( 25℃ ± 10℃ ) and humidity (65℃ CRH±20℃ CRH) our recommendation.
    The Soldering Temperature is 260±5℃ and Soldering Time should be less than 3 sec, and soldering iron power should be less than 30W.
    The soldering point should be farther than 1.6mm from boby.
    For any technical support or suggestion, please kindly go to ourforum.
    See More
    $50 Featured List
    $100 Featured List
    $200 Featured List
    Don’t miss out!
    Questions and Answers
    SUBMIT
    See More
    View History
    Best-sellers
    SUBMIT
    Invalid email address.
