0.8 Inch 16 Segment LED Yellow Green - Common Anode
  • 0.8 Inch 16 Segment LED Yellow Green - Common Anode
SKU 104990120
This product is retired, please consider our SMD LED Clear-Yellow as your alternative choice
Free Express Shipping on Orders over $200!
$1.95
DISCONTINUED
This product is retired, please consider our SMD LED Clear-Yellow as your alternative choice.
This is a 16 segment common cathode LED and is yellow green. The advantage of 16 segment is that you can not only display 1234567890, but also ABCDEFGHIJKLM.
It is compatible with bread board and can work with Arduino by adding some current limiting resistors. So, it Suitable for people who is newbie of electronic.
Note: It just a segment LED without control chip.
Corresponding Interface:
High Light
low current
low-voltage
low energy
Longevity
IC-compatible
Specification:
0.80 inch
common port: 12,17
size: 20.0 x 27.7 x 8.5mm
Colors: Yellow Green
surface colors: Black
Working temperature: -20~60°C
1. Electro-Optical Characteristics(Ta=25℃)
PARAMETER
SYMBOL
DEVICES(ULTRA-BRIGHT RED)
UNIT
TEST
CONDIONS
TYP
MAX
Peak Emission Wavelengrth
λp
565
nm
IF=10mA
Inetnsity
IV
5.5
mcd
IF=10mA
Forward Voltage
VF
2.2
V
IF=10mA
Reverse Current
IR
50
μA
VR=5V
Segment To Segment(Dot ToDot)
Luminonous Intensity Ratio
IV-M
1.5:1
IF=20
2. Absolute Maximun Ratings(Ta=25℃)
PARAMETER
SYMBOL
DEVICES(YELLOW GREEN )
UNIT
Power Dissipation Per Dice
pad
70
mw
Derating Linear From 25℃ Per Dice
0.27
mA/℃
Continuous Forward Current Per Dice
laf
25
mA
Peak Forward Ourrent Per Dice(Duty Cycle 1/10,10KHz)
lpf
90
mA
Reverse Voltage Per Dice
Vr
5
v
Operating Temperature
Topr
-20℃~+75℃
Storage Temperature
Tstg
-20℃~+85℃
Solder Temperature
1.6Inch Below Seating Place for 5 seconds at230℃
See More
$50 Featured List
$100 Featured List
$200 Featured List
Don’t miss out!
Reviews
See More
Questions and Answers
SUBMIT
See More
View History
Best-sellers
SUBMIT
Enjoy $15 off on your first order over $50 or more. Discounted items included!
Invalid email address.
