seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      2.2 Inch Bend Sensor - A201
      • 2.2 Inch Bend Sensor - A201
      SKU 114990106
      • Introduction:
      • This force sensor is an ultra-thin, flexible printed circuit
        $25.95
        DISCONTINUED
        $25.95/1pcs+
        $23.36/10pcs+
        $22.06/20pcs+
        Introduction:
        This force sensor is an ultra-thin, flexible printed circuit. The standard A201 force sensor is constructed of two layers of substrate (polyester) film. The high-temp model (HT201) is constructed of two layers of polyimide.
        On each layer, a conductive material (silver) is applied, followed by a layer of pressure-sensitive ink.
        Adhesive is then used to laminate the two layers of substrate together to form the force sensor.
        The active sensing area is defined by the silver circle on top of the pressure-sensitive ink. Silver extends from the sensing area to the connectors at the other end of the sensor, forming the conductive leads.
        A201 sensors are terminated with male square pins, allowing them to be easily incorporated into a circuit. The two outer pins of the connector are active and the center pin is inactive.
        Features:
        • better linearity
        • measurement of higher loads
        • stable output with respect to load area
        Specification:
        • Physical Properties:
        • Thickness: 0.008 in. (.203 mm)
        • Length:  7.75 in. (197 mm)
        •         6 in. (152 mm)
        •         4 in. (102 mm)
        •         2 in. (51mm)
        • Width: 0.55 in. (14 mm)
        • Sensing Area:  0.375 in. diameter (9.53 mm)
        • Connector: 3-pin male square pin
        Typical Performance:
        • Linearity Error: <±3%
        • Repeatability:<±2.5% of full scale
        • Hysteresis:  <4.5% of full scale
        • Drift:<5% per logarithmic time scale
        • Response Time: <5 microseconds
        • Operating Temperatures:  -40°F - 140°F(-40°C - 60°C)
        • Force Ranges:  0-1 lb (4.4 N), 0-25 lb (110 N),0-100 lb (440 N)
        • Temperature Sensitivity: Output variance up to 0.2% per degree F
        Datasheet
        For any technical support or suggestion, please kindly go to ourforum.
        See More
        $50 Featured List
        $100 Featured List
        $200 Featured List
        Don’t miss out!
        Reviews
        See More
        Questions and Answers
        SUBMIT
        See More
        View History
        Recommendations
        SUBMIT
        Invalid email address.
