seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      2.8 TFT Touch Shield V2.0
      SKU 104030004
      $19.90
      2 Available
      $19.90/1pcs+
        I accept the restriction
      This development board can be only used for prototyping, it cannot be built into a product for commercial distribution. It cannot be re-sold or used as part of a production environment.
      Maximum Qty: 5
      This is a multifunctional Arduino/Seeeduino/Arduino Mega compatible resistive touch screen. It can be used as display device or sketch pad.Compared with the previous version, 2.8’’TFT Touch Shield V1.0, we replaced the screen driver with a more professional chip, ILI9341 driver, providing different pin-saving SPI communication without sacrificing the data transmitting speed. Due to the communication method change, programs developed for the original version need modifications before being transplanted to the new version. With a SD card module integrated also on this shield, this shield reserves great room for other expansions to your project.
      • Big screen for easy and comfortable experience
      • Backlight controllable via programming
      • 65535 rich colors display
      • SPI pin-saving communication method
      • Full screen touch active range
      Technical Details
      Dimensions100mm x 66mm x 30mm
      WeightG.W 56g
      BatteryExclude
      2.8 TFT Touch Shield V2.01
      Reviews
      Questions and Answers
      SUBMIT
      0
      I am fairly new to this, so I decided to use this shield to make an interactive resistor calculator. I downloaded the libraries and figured out how to insert my own colors using HEX. But no matter how many combinations I try for Brown it always comes out looking blue or green. Any suggetsions?
      on Apr 13,2017
      Replyupvote ()
      Hello, seems that it need a bit more in-depth debugging that we can do via comments.Please contact techsupport@seeed.cc with your set up, the code you’re using, and any errors you might be getting.Thanks.
      on Jan 09,2018 10:45 AM
      Replyupvote ()
      Reply
      0
      Will this work with Arduino 101?
      on Dec 25,2016
      Replyupvote ()
      Ron, I read your question, then 10 minutes later I was kickin' around Github downloading libraries for this TFT screen and came across a possible solution for you. I didn't do any of this work, just happened to stumble across it... https://github.com/Seeed-Studio/TFT_Touch_Shield_V2/commit/f21a027d2cf3362f1ea99edba79f6e8358d9ca2c
      on Jan 06,2017 05:41 AM
      Replyupvote ()
      Reply
      When hooking this up by jumpers do I use the ISCP block or the digital pins 11, 12 and 13
      on Jan 09,2018
      Replyupvote ()
      Hi there~ You can use ISCP pins, Or you can use pin D11 D12 D13 after you solder P1,P2,P3.Regards.
      on Jan 09,2018 10:23 AM
      Replyupvote ()
      Reply
      0
      the paint example does not work. I tried to uploud it and an error came up saying that the SeeedTouchScreen.h isn't there. I downloaded the file from git hub and included it in the software through manage libraries in sketch. what should I do.
      on Jul 17,2017
      Replyupvote ()
      Hi there~ Sorry to keep you waiting so long~You need to download the touchscreen driver of seeed at first.Please click here to download ### https://github.com/Seeed-Studio/Touch_Screen_Driver/archive/master.zip ### Then add it to your Arduino IDE.It should be OK.For more info. You can refer to our wiki. Regards
      on Jan 09,2018 10:44 AM
      Replyupvote ()
      Reply
      0
      hola ya encontre la libreria pero quisiera me ayudaran para trabajar con la sd biene algun tipo de sd especial para este shield muchas gracias
      on Nov 14,2016
      Replyupvote ()
      hola use 2GB micro SD card
      on Nov 15,2016 18:39 PM
      Replyupvote ()
      Reply
      0
      hola buen dia porfavor me podrian ayudar como encuentro la libreria de este producto para subirla a arduino estoy confundido soy nuevo en esto muchas gracias espara un proyecto con arduino mega
      on Nov 13,2016
      Replyupvote ()
      Please download the library from the following link https://github.com/Seeed-Studio/TFT_Touch_Shield_V2/archive/master.zip
      on Nov 28,2016 18:05 PM
      Replyupvote ()
      Reply
      0
      Hello Guys , Can it work with NFC Shield V2 ?
      on Oct 19,2016
      Replyupvote ()
      No, It can't work with NFC shield v2.0.
      on Nov 28,2016 18:03 PM
      Replyupvote ()
      Reply
      0
      Hi, Is this currently still the case in the library? Which fixed orientation is it that the text is displayed , portrait or landscape?
      Cheers,
      Gus
      on Oct 19,2016
      Replyupvote ()
      Gus, Just got mine going today. It appears that Text is portrait only with their library.
      on Jan 07,2017 12:07 PM
      Replyupvote ()
      Reply
        View History
        SKU 104030004
        $19.90
        2 Available
        Maximum Qty: 5
        $19.90/1pcs+
        • Best-sellers
        • Description
        • Technical Details
        • Learn
        • Reviews
        • Questions and Answers
        • View History
        SUBMIT
        Invalid email address.
