the AI Hardware Partner
Toggle Nav
Loading...
42 Step Motor Frame - Black
It is used to fix 42 step motor
$4.95
Out of stock
  • 10+: $4.46
It is used to fix 42 step motor.we can reduce the non-standard parts processing when we make the Non-standard equipment and Small production of science and technology,It's Very convenient.
Feature:
1. Strength - It's made by using the steel plate a integrated manufacturing process,and welding reinforcement On both sides of it to ensure enough strength.
2. Dimensions - All the slot and hole are made by using a punching processing of high precision punch that ensure the dimensions accurate absolutely,so it can fit with machine accurately.
3. Surface treatment - Adopting advanced black matt coating that is the best feel,So it's not rub off and rust oxygen when it is used for a long time under the bad environment.
Specification:
Dimensions 80mm x120mm x43mm
Weight G.W 107g
Battery Exclude
HSCODE 7326909000
USHSCODE 7326908630
UPC 841454114369
EUHSCODE 7616991091
COO CHINA
RoHS 1
