5mm Triple Output LED RGB - Common Anode (20 PCs)
SKU 110990058
5.00
12 Available
$5.00/ 1pcs+
$4.50/ 10pcs+
This pack contains 20 units of 5mm LED RGB - Common Anode.
Chip Material
Lens Type
Emitting
Forward Voltage(V)
Dominant Wavelength(nm)
Luminous Intensity(mcd)
Reverse Current(uA)
Viewing Angel(deg)
InGaN
Water Clear
Red
1.8/2.5
615/645
200/600
10
±60
InGaN
Water Clear
Green
2.8/4.0
455/480
200/400
10
±60
InGaN
Water Clear
Blue
2.8/4.0
500/540
300/800
10
±60
IF=20mA
IF=20mA
IF=20mA
VR=5V
IF=20mA
Technical Details
Dimensions100mm x 75mm x 7mm
WeightG.W 9.90g
BatteryExclude
5mm Triple Output LED RGB - Common Anode (20 PCs)1
ECCNNot Available
HSCODE8541401000
Certification
RoHSCompliant
Reviews
Questions and Answers
SUBMIT
0
PIN 1 is red, PIN 2 is COMMON CATHODE, PIN 3 is GREEN, PIN 4 is BLUE.I Hope that there is not another mistake (like forward voltage...)
on Oct 19,2016
Reply upvote ()
Actually we are preparing the G3/4 module.
on Oct 20,2016 10:41 AM
Reply upvote ()
Actually there are two different SKU's, one common anode (this one) and one common cathode (the other one). Be sure you order the right one.
on Oct 20,2016 10:48 AM
Reply upvote ()
Reply
0
are this LED's Diffused?
on Oct 19,2016
Reply upvote ()
I would like to discuss volume purchasing. Can you email me your number so we can discuss? My email is villeric@gmail.com. Thank You!
Reply upvote ()
No.
Reply upvote ()
No.
Reply upvote ()
Reply
0
what the Luminous Intensity of each color?
on Oct 19,2016
Reply upvote ()
    View History
    SKU 110990058
    $5.00
    12 Available
    $5.00/ 1pcs+
    $4.50/ 10pcs+
    • Description
    • Technical Details
    • Reviews
    • Questions and Answers
    SUBMIT
