seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      6GHz 2W SMA Attenuator - 30dB
      SKU 320160017
      $24.95
      24 Available
      $24.95/1pcs+
      $22.46/50pcs+
        I accept the restriction
      This development board can be only used for prototyping, it cannot be built into a product for commercial distribution. It cannot be re-sold or used as part of a production environment.
      Maximum Qty: 5
      SMA attenuators are used to reduce the input power, and therefore enable RF Explorer to measure stronger signals. It is also used to protect the input SMA port of RF Explorer when unknown strong signals may be in the environment, so you can use this attenuator on demand. You can easily unplug the attenuator when measurement is for weak signals.
      You can also daisy chain multiple attenuators to get additional values. For instance a 10 dB + 30dB attenuators connected in series will give you 40dB total attenuation.
      RF Explorer firmware includes an “Offset DB” feature in the Attenuator Menu, you should specify (+030) dB in this setting when the attenuator is connected in order to get correct readings on screen.
      This powerful 30dB attenuator will work reliably up to 6GHz and 2W input power.
      Seethis article for more details on protection of your RF Explorer.
      Feature
      • Reliable V.S.W.R
      • Easy maintenance
      • Wide broadband frequency application
      • Directional 2 Watt rating
      • Frequency range: DC - 6.0 GHz
      • Impedance (Nominal): 50Ω
      • Power rating: 2 Watt (+33dBm)
      • Attenuation: 30 dB
      • Tolerance: +/- 0.5dB/max
      • V.S.W.R (Max): 1.22 : 1
      • Connector type: SMA male - female
      Technical Details
      Dimensions55mm x 55mm x 9.6mm
      WeightG.W 10g
      BatteryExclude
      6GHz 2W SMA Attenuator - 30dB1
      Documents
      Reviews
      Questions and Answers
      SUBMIT
        View History
        SKU 320160017
        $24.95
        24 Available
        Maximum Qty: 5
        $24.95/1pcs+
        $22.46/50pcs+
        • Best-sellers
        • Description
        • Technical Details
        • Reviews
        • Questions and Answers
        • View History
        SUBMIT
        Invalid email address.
