seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      6GHz 2W SMA Attenuator - 60dB
      SKU 310120001
      $45.00
      6 Available
      $45.00/1pcs+
      $40.50/50pcs+
      ADD TO CART
      SMA attenuators are used to reduce the input power, and therefore enable RF Explorer to measure stronger signals. Attenuators are also used to protect the input SMA port of RF Explorer when unknown strong signals may be in the environment, so you can use this attenuator on demand. You can easily unplug the attenuator when measurement is for weak signals.
      This robust attenuator is custom made, high quality exceptional value 60dB total attenuation. You will not find attenuators of this range anywhere else in the market, the only other option is to daisy chain two 30dB attenuators together. Therefore, this unit is cost effective option to measure high power RF signals. A 60dB attenuation enables any RF Explorer unit to measure signals of up to 2Watt (33dBm) power without distortion with a single attenuator, as opposed to connecting multiple attenuators in daisy chain.
      RF Explorer firmware includes an"Offset DB"feature in the Attenuator Menu, you should specify (+060) dB in this setting when the attenuator is connected in order to get correct readings on screen.
      See this article for more details on protection of your RF Explorer.
      • Reliable V.S.W.R
      • Easy maintenance
      • Wide broadband frequency application
      • Directional 2 Watt rating
      • Single attenuator enough to measure up to 2Watt power with RF Explorer
      • Frequency range: DC - 6.0 GHz
      • Impedance (Nominal): 50Ω
      • Power rating: 2 Watt (+33dBm)
      • Attenuation: 60 dB
      • Tolerance: +/- 2dB/max
      • V.S.W.R (Max): 1.25 : 1
      • Connector type: SMA male - female
      • 1 x 6GHz 2W SMA Attenuator - 60dB
      Documents
      For technical support and suggestions, please visit our forum.
      Technical Details
      WeightG.W 19g
      BatteryExclude
      6GHz 2W SMA Attenuator - 60dB1
      Reviews
      Questions and Answers
      SUBMIT
        View History
        SKU 310120001
        $45.00
        6 Available
        ADD TO CART
        $45.00/1pcs+
        $40.50/50pcs+
        • Best-sellers
        • Description
        • Technical Details
        • Reviews
        • Questions and Answers
        • View History
        SUBMIT
        Invalid email address.
