the AI Hardware Partner
Toggle Nav
Loading...
86Duino EduCake - an all-in-one embedded platform based on Vortex86EX SoC
Compatible with Arduino Vortex86EX Processor,300MHz 32-bit x86, 128MB DDR3 Support DOS, Windows, Linux
$59.00
Out of stock
EduCake is designed to be compatible with Arduino series. It is an all-in-one design with an integrated bread board. Many electronic components, sensors and accessories can be easily connected or replaced for experiment without soldering process. Its built-in special circuit protection design can prevent it from burn out due to configuration errors. You can make a module easily, quickly and also be worry free about unexpected damage caused by human factor.
  • Vortex86EX Processor
- 300MHz 32-bit x86
- 128MB DDR3
- LAN
- USB 2.0
- Micro-SD
  • Open-Source Hardware
  • Support DOS, Windows, Linux
  • Arduino-Compatible IDE
Specifications
  • Processor: Vortex86EX
  • Clock Speed: 300 MHz
  • Memory: 128MB DDR3
  • Flash Memory: 8MB
  • Digital I/O Pins: 45 (of which 11 provide 32bit PWM output)
  • Analog Input Pins: 7 (11bit)
  • Operating Voltage: 5V
  • Input Voltage (recommended): 7-12V
  • DC Current per I/O Pin: 16 mA
  • DC Current for 3.3V Pin: 400 mA
Documentations
Dimensions 0mm x0mm x0mm
Weight G.W 228g
Battery Exclude
