8x8 RGB LED Dot Matrix - Compatible with Rainbowduino
SKU 104990026
18.50
7 Available
$18.50/ 1pcs+
Do you know how is the cool advertising display made? It is exactly composed of these small RGB LED matrix. If you want to make a similar display, this RGB LED matrix will meet you need. The 8x8 LED matrix has 32 of pins, you may need a driver to control it. It sounds quite complex, but don't worry, we have provided a driver board Rainbowduino for this LED matrix as your reference. Make it easy for you to start your project.
  • Fully compatible with Rainbowduino
  • Full color RGB variation
  • Circular LED point source
Specifications (IF = 20mA)
  • Forward voltage(RED): DC 2.2V
  • Forward voltage(GREEN): DC 3.3V
  • Forward voltage(BLUE): DC 3.3V
  • Luminous intensity(RED): 140mcd
  • Luminous intensity(GREEN): 280mcd
  • Luminous intensity(BLUE): 80mcd
  • Wavelength(RED): 620~622.5nm
  • Wavelength(GREEN): 520~522.5nm
  • Wavelength(BLUE): 465~467.5nm
Documents
Technical Details
Dimensions65mm x 90mm x 18mm
WeightG.W 31g
BatteryExclude
ECCNNot Available
HSCODE8531200000
Certification
RoHSCompliant
Reviews
Questions and Answers
SUBMIT
0
Dear Seeed, I bought the 2088RGB and would like to use 74HC595 for some testing, could you provide the connection chart for pins because datasheet provide only schematic connection. In 2088RGB threr are 16 pins top and 16 pins bottom without numeration
on Oct 19,2016
Reply upvote ()
Hi, on the bottom right corner , that is sign '1' .And the number and color is writed at the schematic circuit.Please check carefully again ,thanks.
on Oct 20,2016 10:42 AM
Reply upvote ()
Reply
0
Hello, is this matrix compatible with my Rainbowduino v1.2 dated 07/17/09?Thanks!
on Oct 19,2016
Reply upvote ()
Yes,it compatible with my Rainbowduino v1.2 dated 07/17/09.
Reply upvote ()
Reply
    View History
    SKU 104990026
    $18.50
    7 Available
    $18.50/ 1pcs+
    • Description
    • Technical Details
    • Reviews
    • Questions and Answers
    SUBMIT
