AlphaBot, Mobile robot development platform
SKU 110090145
$31.49$44.99
OUT OF STOCK
This item is not available at the moment
Get notified when it's back in stock
AlphaBot is a robotic development platform compatible with Raspberry Pi and Arduino. It consists of the AlphaBot mainboard, the mobile chassis, and everything required to get it moving.
Just connecting a controller board, Raspberry Pi or Arduino, and combined with our open source example code, now it's all ready to start your robotic exploration: line tracking, obstacle avoidance, video monitoring, WiFi/Bluetooth/ZigBee/Infrared remote control, etc.
Raspberry Pi or Arduino is NOT included in the price.
AlphaBot Features
  • Raspberry Pi/Arduino interfaces, works with either one separately, or both
  • Arduino extend header, supports Arduino shields
  • Modular design, plug-and-play modules like line tracking, obstacle avoidance, speed measuring, etc. eliminating the trouble of connecting mess wires.
  • LM298P motor driver with diode protection circuit, more safety
  • LM2596 voltage regular, provides stable 5V power to the Raspberry Pi/Arduino
  • TLC1543 AD acquisition chip, allows the Pi to use analog sensors
Raspberry Arduino Robot AlphaBot on board resource
1.    Raspberry Pi interface: for connecting Raspberry Pi
2. Arduino interface: for connecting Arduino
3. Motor interface
4. Ultrasonic module interface
5. Servo module interface
6. Obstacle avoidance module interface
7. Speed measuring interface
8. Battery holder: supports 18650 batteries
9. Reserved power input (not soldered): for connecting other external power supply
10. Arduino expansion header: for connecting Arduino shields
11. UART interface: for connecting Bluetooth module, to control the robot remotely via Bluetooth
12. SPI interface: for connecting NRF24L01 wireless module
13. Line tracking module interface
14. TLC1543: 10-bit AD acquisition chip, allows the Pi to use analog sensors
15. LM298P: dual H bridge motor driver chip, up to 2A current
16. Anti-reverse diode
17. Power switch
18. LM2596: 5V regulator
19. Power indicator
20. UART switch: turn on to enable serial communication between Raspberry Pi and Arduino
21. IR receiver: control the robot remotely via infrared
22. Raspberry Pi/Arduino selection: select the Raspberry Pi or Arduino to control the robot peripherals
Infrared line tracking robot
Infrared obstacle avoidance robot
Ultrasonic obstacle avoidance robot
Infrared/Bluetooth remote control robot
Video monitoring robot
Note: photos are FOR REFERENCE ONLY, the other boards/modules/accessories are NOT included in the price.
Please visit Wiki for more information.
Package ContentsProducts
ItemDescriptionAlphaBotAlphaBot-Ar-BasicAlphaBot-Ar-BluetoothAlphaBot-Pi Acc PackAlphaBot-Pi
RPi3 BRaspberry Pi 3 Model B
UNO PLUSenhanced control board, Arduino compliant
AlphaBot chassis kitmainboard, wheels, drivers, etc.
Tracker Sensorline tracking module
Photo Interrupter Sensorspeed measuring module (2pcs)
Infrared Proximity Sensorobstacle avoidance module (2pcs)
IR remote controllerremotely control the robot
SG90servo
Ultrasonic sensorultrasonic obstacle avoidance, distance measuring
Accessory Shieldaccessories add-on board, Arduino compliant
Dual-mode Bluetoothdual-mode Bluetooth module
RPi Camera (B) Raspberry Pi camera, adjustable focus
Micro SD Card 16GB16GB Micro SD Card, class 10
5V 2.5A Power AdapterRPi3 B requires 2.5A or above power supply
Note: this product requires two 18650 batteries to work, which are NOT included and should be purchased separately.
  1. AlphaBot mainboard x1
  2. Tracker Sensor x1
  3. Photo Interrupter Sensor x2
  4. Infrared Proximity Sensor x2
  5. Motor with gearbox 2PCS x1
  6. AlphaBot wheel 2PCS x1
  7. AlphaBot acrylic chassis x1
  8. Motor mounting plate 4PCS x1
  9. omni-direction wheel x1
  10. 20-slots encoder disk 2PCS x1
  11. IR remote controller x1
  12. XH2.54 4cm 4Pin 2PCS x1
  13. XH2.54 4cm 3Pin 2PCS x1
  14. XH2.54 4cm 7Pin x1
  15. AlphaBot screws x1
Technical Details
Dimensions0mm x 0mm x 0mm
WeightG.W 431g
BatteryExclude
ECCNNot Available
HSCODE9023009000
Reviews
Questions and Answers
SUBMIT
0
what are the characteristics of the dc motor ?
on Oct 09,2017
Reply upvote ()
Hi~please be more specific,what characteristics do you want to know?
on Oct 10,2017 11:32 AM
Reply upvote ()
what are the supply tension, the torque and its reference number ?
on Nov 13,2017 19:00 PM
Reply upvote ()
Reply
0
on Nov 06,2017
Reply upvote ()
We have emailed the supplier, Unfortunately they do not test. They only know the reduction rate is 1:48.
on Nov 14,2017 18:06 PM
Reply upvote ()
Reply
    View History
    SKU 110090145
    $31.49$44.99
    OUT OF STOCK
    $44.99/ 1pcs+
    • Description
    • Technical Details
    • Reviews
    • Questions and Answers
    SUBMIT
