seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      AlphaBot, Raspberry Pi robot building kit
      SKU 110090143
      $111.99
      5 Available
      $111.99/1pcs+
      $109.99/2pcs+
      $108.49/5pcs+
      $99.00/10pcs+
        I accept the restriction
      This development board can be only used for prototyping, it cannot be built into a product for commercial distribution. It cannot be re-sold or used as part of a production environment.
      Maximum Qty: 5
      This kit comes with Raspberry Pi 3 Model B, AlphaBot robotic platform (line tracking, obstacle avoidance, speed measuring, IR control), and a camera (with servo and 2 DOF pan head).
      With modules in the kit, you can fast get started with robotic development like line tracking, obstacle avoidance, IR remote control, and video monitoring via network, etc. What's more, thanks to the rich Raspberry Pi open source resources, and the modular design of AlphaBot, you'll learn how to extend and refit, and finally build your own Raspberry Pi robot.
      Raspberry Pi 3 Features
      • BCM2837, 1.2GHz 64-bit quad-core ARM Cortex-A53
      • 1GB RAM
      • 10/100 Ethernet port
      • 802.11n WiFi NIC
      • Bluetooth 4.1 & Bluetooth Low Energy (BLE)
      • HDMI port
      • USB 2.0 interface x 4
      • Micro SD card slot
      • Combined 3.5mm audio jack and composite video
      • 40-pin GPIO interface
      • Camera interface (CSI)
      • Display interface (DSI)
      • Upgraded power management, supports more peripherals (requires a 2.5A power supply or above)
      AlphaBot Features
      • Raspberry Pi/Arduino interfaces, works with either one separately, or both
      • Arduino extend header, supports Arduino shields
      • Modular design, plug-and-play modules like line tracking, obstacle avoidance, speed measuring, etc. eliminating the trouble of connecting mess wires.
      • LM298P motor driver with diode protection circuit, more safety
      • LM2596 voltage regular, provides stable 5V power to the Raspberry Pi/Arduino
      • TLC1543 AD acquisition chip, allows the Pi to use analog sensors
      Raspberry Arduino Robot AlphaBot on board resource
      1Raspberry Pi interface: for connecting Raspberry Pi
      2. Arduino interface: for connecting Arduino
      3. Motor interface
      4. Ultrasonic module interface
      5. Servo module interface
      6. Obstacle avoidance module interface
      7. Speed measuring interface
      8. Battery holder: supports 18650 batteries
      9. Reserved power input (not soldered): for connecting other external power supply
      10. Arduino expansion header: for connecting Arduino shields
      11. UART interface: for connecting Bluetooth module, to control the robot remotely via Bluetooth
      12. SPI interface: for connecting NRF24L01 wireless module
      13. Line tracking module interface
      14. TLC1543: 10-bit AD acquisition chip, allows the Pi to use analog sensors
      15. LM298P: dual H bridge motor driver chip, up to 2A current
      16. Anti-reverse diode
      17. Power switch
      18. LM2596: 5V regulator
      19. Power indicator
      20. UART switch: turn on to enable serial communication between Raspberry Pi and Arduino
      21. IR receiver: control the robot remotely via infrared
      22. Raspberry Pi/Arduino selection: select the Raspberry Pi or Arduino to control the robot peripherals
      Infrared line tracking robot
      Infrared obstacle avoidance robot
      Ultrasonic obstacle avoidance robot
      Infrared/Bluetooth remote control robot
      Video monitoring robot
      Note: photos are FOR REFERENCE ONLY, the other boards/modules/accessories are NOT included in the price.
      Please visit Wiki for more information.
      Package ContentsProducts
      ItemDescriptionAlphaBotAlphaBot-Ar-BasicAlphaBot-Ar-BluetoothAlphaBot-Pi Acc PackAlphaBot-Pi
      RPi3 BRaspberry Pi 3 Model B
      UNO PLUSenhanced control board, Arduino compliant
      AlphaBot chassis kitmainboard, wheels, drivers, etc.
      Tracker Sensorline tracking module
      Photo Interrupter Sensorspeed measuring module (2pcs)
      Infrared Proximity Sensorobstacle avoidance module (2pcs)
      IR remote controllerremotely control the robot
      SG90servo
      Ultrasonic sensorultrasonic obstacle avoidance, distance measuring
      Accessory Shieldaccessories add-on board, Arduino compliant
      Dual-mode Bluetoothdual-mode Bluetooth module
      RPi Camera (B) Raspberry Pi camera, adjustable focus
      Micro SD Card 16GB16GB Micro SD Card, class 10
      5V 2.5A Power AdapterRPi3 B requires 2.5A or above power supply
      Note: this product requires two 18650 batteries to work, which are NOT included and should be purchased separately.
      1. AlphaBot mainboard x1
      2. Tracker Sensor x1
      3. Photo Interrupter Sensor x2
      4. Infrared Proximity Sensor x2
      5. Motor with gearbox 2PCS x1
      6. AlphaBot wheel 2PCS x1
      7. AlphaBot acrylic chassis x1
      8. Motor mounting plate 4PCS x1
      9. omni-direction wheel x1
      10. 20-slots encoder disk 2PCS x1
      11. IR remote controller x1
      12. XH2.54 4cm 4Pin 2PCS x1
      13. XH2.54 4cm 3Pin 2PCS x1
      14. XH2.54 4cm 7Pin x1
      15. AlphaBot screws x1
      Technical Details
      WeightG.W 675g
      BatteryExclude
      Reviews
      Questions and Answers
      SUBMIT
        View History
        SKU 110090143
        $111.99
        5 Available
        Maximum Qty: 5
        $111.99/1pcs+
        $109.99/2pcs+
        $108.49/5pcs+
        $99.00/10pcs+
        • Best-sellers
        • Description
        • Technical Details
        • Reviews
        • Questions and Answers
        • View History
        SUBMIT
        Invalid email address.
