AlphaBot2 robot building kit for Raspberry Pi Zero/Zero W (no Pi)
$85.99
In stock
3 Available
Qty Discount available
  • $81.69 /10pcs+
  • $77.39 /20pcs+
  • $73.09 /50pcs+
Note: Raspberry Pi Zero/Zero W is NOT included.
This AlphaBot2 robot kit is designed to use with Raspberry Pi Zero/Zero W (not included). It features rich common robot functions including line tracking, obstacle avoiding, ultrasonic ranging, Bluetooth/infrared/Wi-Fi remote control (Bluetooth and Wi-Fi are Zero W specific), video monitoring, etc.
Thanks to the highly integrated modular design, it is fairly easy to assemble by a snap, no soldering, no wiring. After a few minutes spent on hardware assembled, you're almost there, our open source demo codes will ready to help you get started fast.
AlphaBot2 employs a 2-layer structure to provide excellent stability and compatibility.
AlphaBot2-Base, the lower base chassis:
• 5-ch infrared sensor, analog output, combined with PID algorithm, stable line tracking
• Onboard modules like line tracking, obstacle avoiding, needs no messy wiring
• TB6612FNG dual H-bridge motor driver, compared with L298P, it's more efficient, more compact, and less heating
• N20 micro gear motor, with metal gears, low noise, high accuracy
• Onboard RGB LEDs, true color lighting, pretty cool
AlphaBot2-PiZero, the upper adapter board for controller:
• LM2596 voltage regulator, provides the Pi with stable 5V power
• TLC1543 AD acquisition chip, allows the Pi to use analog sensors
• PCA9685 servo controller, make it more smoothly to rotate the pan head
• CP2102 UART converter, easy for controlling the Pi via UART
• USB HUB chip, more USB ports for devices like NIC
What's on the AlphaBot2-Base
1. AlphaBot2 control interface: for connecting sorts of controller adapter board
2. Ultrasonic module interface
3. Obstacle avoiding indicators
4. Omni-direction wheel
5. ST188: reflective infrared photoelectric sensor, for obstacle avoiding
6. ITR20001/T: reflective infrared photoelectric sensor, for line tracking
7. Potentiometer for adjusting obstacle avoiding range
8. TB6612FNG dual H-bridge motor driver
9. LM393 voltage comparator
10. N20 micro gear motor reduction rate 1:30, 6V/600RPM
11. Rubber wheels diameter 42mm, width 19mm
12. Power switch
13. Battery holder: supports 14500 batteries
14. WS2812B: true color RGB LEDs
15. Power indicator
What's on the AlphaBot2-PiZero
1. AlphaBot2 control interface: for connecting AlphaBot2-Base
2. LM2596: 5V voltage regulator
3. Raspberry Pi interface: for connecting Raspberry Pi Zero/Zero W
4. IR receiver
5. Buzzer
6. FE1.1S: USB HUB chip
7. 12M crystal
8. USB TO UART: easy for controlling the Pi via UART
9. USB HUB interface: extends the USB port of Raspberry Pi Zero/Zero W
10. CP2102: USB TO UART converter
11. PCA9685: servo controller, make it more smoothly to rotate the pan head
12. TLC1543: 10-bit AD acquisition chip, allows the Pi to use analog sensors
13. Servo interface
14. USB indicators
15. USB ports: more USB capability
Examples
Note: photos are FOR REFERENCE ONLY, the other boards/modules/accessories are NOT included in the package list.
Dimensions 220mm x165mm x70mm
Weight G.W 399g
Battery Exclude
AlphaBot2-PiZero (adapter board) 1
AlphaBot2-Base (base chassis) 1
RPi Camera (B) 1
Ultrasonic sensor 1
Micro SD Card 16GB 1
Power adapter US standard 5V/2.5A USB output 1
SG90 servo 2
2 DOF pan and tilt kit 1
IR remote controller 1
FC-20P cable 8cm 1
Micro USB connector 1
RPi Zero V1.3 Camera Cable 30cm 1
USB type A plug to micro B plug cable 1
AlphaBot2-PiZero screws 1
Screwdriver 1
Micro SD Card Reader 1
ECCN ERA99
HSCODE 8479899990
AlphaBot2-PiZero
AlphaBot2-PiZero robot kits includes a chassis (AlphaBot2-Base chassis) and an adapter board AlphaBot2-PiZero. The robot supports Raspberry Pi with AlphaBot2-PiZero adapter board.
Product Faqs
Sort by
