the AI Hardware Partner
Toggle Nav
Loading...
Aluminum Shaft Coupler(5-5mm)
These stainless Aluminum shaft couplers allow you to couple the same size shafts together
$1.90
Out of stock
These stainless Aluminum shaft couplers allow you to couple the same size shafts together. They can be used for connecting motor shafts to drive shafts, or two same sized shafts. All of they come with a hex wrench.
Specification:
  • Length: 25mm
  • Diameter: 14mm
  • Bore: 5-5mm
  • Weight: 9.2g
Part List:
  • 1 x Aluminum shaft couplers
  • 4 x Net
  • 1 x Allen driver
Dimensions 0mm x0mm x0mm
Weight G.W 12g
Battery Exclude
HSCODE 8483600090
ROHS 1
