HPS-3D160-U Solid-State LiDAR
HPS-3D160 is a new generation high-performance solid-state LiDAR sensor based on the principle of ToF, with optimized lighting system and low distortion infrared optical lens, measure distance up to 15m on 90% reflective rate white target
$269.00
In stock
  • 2+: $259.00
  • 50+: $249.00
HPS-3D160 is a new generation high-performance solid-state LiDAR sensor based on the principle of ToF, with optimized lighting system and low distortion infrared optical lens, measure distance up to 12m on 90% reflective rate white target. Flexible customize ROI setting function, Simple-HDR, Auto-HDR, and Super-HDR mode, make HPS-3D160 widely used in all reflectivity scenes.
HPS-3D160 integrates a high-power 850nm infrared VCSEL emitter and a high-sensitivity photosensitive device, embedded high-performance processor and advanced data process, filter and compensation algorithm, enables very stable and simultaneous measure data output. Full solid structure, industrial IP67 waterproof design and strong aerospace aluminum housing allows the HPS-3D160 to be used in a variety of complex environments
  • Full-field of view frame up to 35 fps
  • Field of View: 76° x 32°,Resolution: 160 x 60
  • Support 16 groups of users customize region of interest setting, each group support 8 regions of interest
  • Available with USB communication.
  • Support GPIO input measurement simultaneously.
  • Measures range up to 15m
  • Range accuracy: points cloud in centimeter
  • Excellent ambient light suppression ability
  • Embedded anti-interference algorithm, support multi-machine work
  • Total solid structure, industrial IP67 anti-water design
  • Support Simple-HDR mode, Auto-HDR mode and Super-HDR mode, with fine scene adaptability.
Applications
  • Robotics & AGV automatic navigated robot(obstacle detection,SLAM application)
  • Drone collision avoidance,altitude hold
  • Industrial safety area protection and proximity protection
  • Safety surveillance
  • 3D movement recognition
  • 3D modeling
HPS-3D160 Application
Dimensions 78mm x40mm x30mm
Weight G.W 140g
Battery Exclude
Power supply 12 ~ 24 V
Maximum power consumption 6 W
Quiescent power consumption 0.7 W
Storage temperature -40 ~ 85℃
Operating temperature -10 ~ 55℃
Infrared VCSEL emitter 850 nm
Emitting angle 76(horizontal)x 32(vertical)°
Maximum measuring distance 15 m
Minimum measuring distance 0.25 m
Maximum output frame rate Full field of view 35 fps
Output data Depth data, average distance, signal strength, weak signal pixels quantity, saturated pixels quantity, maximum distance, minimum distance
Operating mode Operating mode
Power-on initialization time 1500 ms
Interface USB
Optocoupler isolation IO standard:input x 1,output x 1
Cable length 200 cm
HPS-3D160 Solid-State LiDAR 1
ECCN EAR99
HSCODE 9031809090
UPC 841454121817
FCC 1
CE 1
Product Faqs
Sort by
