seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      Base Shield V2
      Base Shield V2
      SKU 103030000
      $8.90
      26 Available
      $8.90/1pcs+
      $8.01/10pcs+
      $7.57/20pcs+
      $7.12/50pcs+
      ADD TO CART
      Arduino Uno is the most popular Arduino board so far, however it is sometimes frustrating when your project requires a lot of sensors or Leds and your jumper wires are in a mess. The purpose of creating the Grove – Base Shield is to help you getting rid of bread board and jump wires. With the rich grove connectors on the base board, you can add all the grove modules to the Arduino Uno very conveniently!
      There are intotal 16 grove connectors on the Base Shield, here we use a table to show the details.
      Name
      Qty
      Analog
      A0/A1/A2/A3
      4
      Digital
      D2/D3D4/D5/D6/D7/D8
      7
      UARTUART
      1
      I2C
      I2C
      4
      Apart from the rich grove connectors, on the board you can also see an RST button, a green LED to indicating power status, ICSP pin, a toggle switch and four row of pinouts. There is no need to explain the RST button and LED, but you really need to know below two features that is very important for your usage.
      1.Power Compatible:
      Every Grove connector has four wires, one of which is the VCC. However, not every micro-controller main board needs a supply voltage of 5V, some need 3.3V. That's why we add a power toggle switch to Base Shield v2 so that you can select the suitable voltage of the micro-controller main board you are using via this switch.
      For example, if you are using Arduino UNO with Base Shield v2, please turn the switch to 5v position; while using Seeeduino Arch with Base Shield v2, please turn the switch to 3.3v.
      2.Board Compatible:
      The pinout of Base Shield V2 is the same as Arduino Uno R3, however Arduino Uno is not the board one that the Base Shield V2 is compatible with, here we listed the boards that we have confirmed that can be used with Base Shield V2.
      • Arduino Uno
      • Seeeduino V4.2
      • Arduino Mega / Seeeduino Mega
      • Seeduino LoraWan
      • Arduino Leonardo / Seeeduino Lite
      • Arduino 101
      • Arduino Due
      • Intel Edison
      • Linkit One
      Note
      • If using Base Shield v2 with Seeeduino V3, please solder the pads, P1 and P2.
      Technical Details
      Dimensions69mm x 53mm x 23mm
      WeightG.W 25g
      BatteryExclude
      Base Shield V21
      Reviews
      Questions and Answers
      SUBMIT
      0
      Hi, I plugged the Grove Base shield into an Intel Edison for Arduino kit that I had previously flashed with Ostro OS. Now the serial console can no longer connect to the Edison and the green power LED is not lighting up on the Grove base shield. Is there some setting I need to make or is there something wrong with the Grove Base Shield?
      on Aug 31,2017
      Replyupvote ()
      Hi Paul, the base shield is quite simple and just route the signals. we would suggest you plug the base shield into arduino boards and do the validation. thanks. Bill
      on Nov 27,2017 17:16 PM
      Replyupvote ()
      Reply
      0
      hi, is this compatible with the Arduino Mega2560 R3?
      on Nov 11,2016
      Replyupvote ()
      work better with Mega 2560
      on Feb 17,2017 20:39 PM
      Replyupvote ()
      Replyupvote ()
      Reply
      0
      Hi
      on Aug 31,2017
      Replyupvote ()
      hi , what‘s up
      on Jan 10,2018 16:59 PM
      Replyupvote ()
      Reply
      0
      Is this compatible with the Seeeduino Stalker V3.1?
      on Jun 02,2017
      Replyupvote ()
      Hi Dear Customer, it is compatible. thanks. Bill
      on Nov 27,2017 17:13 PM
      Replyupvote ()
      Reply
      1
      how do the analog ports work? i want to use it to capture a voltage signal(0.5v - 4.5v), can i use this shield and how to handle it?
      on Nov 04,2016
      Replyupvote ()
      Hi Dear Customer, you can connect the base shield to arduino board, then plug the sensor into A0~A3 port, then you can use analogRead to read the number. Coz the arduino is 10 bit ADC, so the max is 1023. you can map the reading with actual voltage signal. thanks. Bill
      on Nov 27,2017 17:12 PM
      Replyupvote ()
      Reply
      0
      Is this shield compatible with the arduino Yun ? Thank
      on Jul 17,2017
      Replyupvote ()
      Yes, it is compatible. thanks. Bill
      on Nov 27,2017 17:10 PM
      Replyupvote ()
      Reply
        View History
        Base Shield V2
        SKU 103030000
        $8.90
        26 Available
        ADD TO CART
        $8.90/1pcs+
        $8.01/10pcs+
        $7.57/20pcs+
        $7.12/50pcs+
        • Best-sellers
        • Description
        • Technical Details
        • Learn
        • Reviews
        • Questions and Answers
        • Related
        • View History
        SUBMIT
        Invalid email address.
