BeagleBone® Black - Embest
BeagleBone® Black - circuitco BeagleBone® Black - Embest BeagleBone® Black - Embest RevC BeagleBone® Black is a development kit based on an AM3359 processor which integrates an ARM Cortex™-A8 core operating at up to 1GHz and
$69.00
Out of stock
BeagleBone® Black is a development kit based on an AM3359 processor which integrates an ARM Cortex™-A8 core operating at up to 1GHz and has abundant peripheral devices. BB Black provides lots of expansion interfaces such as Ethernet, USB host and OTG, TF card, serial, JTAG (no connector by default), HDMI D type, Emmc, ADC, I2C, SPI, PWM and LCD. BB Black is designed to satisfy the different requirements of various fields including game devices, home and industrial automation, consumer medical devices, printers, intelligent tolling systems, weighing systems of intelligent vending machine, educational terminals and high-end toys.
Features:
AM3359 Processor:
   • Integrating 1GHz ARM Cortex™-A8 core
   • Integrating NEON™ SIMD coprocessor
   • Integrating SGX530 graphics engine
   • Integrating programmable real-time unit subsystem
   • Integrating 32KB instruction buffer and 32KB data buffer with single-error detection (parity)
   • Integrating 256KB L2 cache with error-check code
• On-Board Memories:
   • 2G eMMC Flash
   • 512MB DDR3 SDRAM
• On-Board Interfaces:
   • 1 HDMI D type interface (16-bit color with audio output)
   • 1 LCD interface (24-bit output, extended by P8 interface)
   • 1 10/100M Ethernet (RJ45 connector)
   • 1 high-speed USB 2.0 OTG interface with PHY (Mini USB type-B connector)
   • 1 high-speed USB 2.0 HOST interface with PHY (USB type-A connector)
   • 1 TF card slot (SD/MMC)
   • 1 3-line debugging serial interface (6-pin 2.54-pitch connector)
   • 1 HDMI type-D interface
   • 1 expansion interface for LCD, UART, eMMC, ADC, I2C, SPI and PWM
   • 1 JTAG interface (optional item, 20-pin standard interface, no connector mounted by default)
• Buttons & LEDs:
   • 1 boot device selection button
   • 1 power button
   • 1 reset button
   • 1 LED power indicator
   • 4 user custom indicators
Specifications:
   • dimensions: 86.36 mm×54.61mm
   • Operation Temperature: 0 ~ 70℃
   • Operating Humidity: 20% ~ 90% (Non-Condensing)
   • Power Supply: 5V/0.35A
System Block Diagram
Package Include:
  • 1 x Beaglebone® Black –Embest Version main board
  • 1 x Mini USB Cable
  • 1 x Package box
Software:
Items
Notes
OS
Linux
Ångström Linux    (Kernel Linux3.8)
Device Driver
Uart
Uart Driver
Ehternet
10/100 IEEE1588
Display
HDMI Driver
mmc/sd
SD 2.0 /eMMC Driver
USB
High speed USB Host Driver
Led
User LED Driver
  • Supported by Angstom systems for BeagleBone® Black and shipped with drivers and source code
  • Supported by TISDK system for BeagleBone® and shipped with drivers and source code
For more information, please click here
Dimensions 0mm x0mm x0mm
Weight G.W 133g
Battery Exclude
Product Faqs
Sort by
