seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      Bit:Bot - Robot Kit for Micro:Bit
      SKU 114991414
      $49.95
      7 Available
      $49.95/1pcs+
        I accept the restriction
      This development board can be only used for prototyping, it cannot be built into a product for commercial distribution. It cannot be re-sold or used as part of a production environment.
      Maximum Qty: 5
      Fully-integrated robot for the micro:bit.
      This (almost) ready-assembled robot requires no soldering, no wires and nothing more than a screwdriver to complete it.
      The Bit:Bot fully engages children and adults alike, allowing you to explore and code the micro:bit using any of the languages available (not all features are supported in all languages).
      Features:
      • 2 micro-metal gear motors. Both fully controllable in software, for both speed (0 to 100%) and direction (forward or reverse)
      • Wheels with rubber tyres for maximum grip
      • Really smooth metal ball front caster
      • 12 mini neopixels in 2 sets of 6 along the arms either side. Select any colour for any pixel, produce stunning lighting effects as your Bit:Bot moves around
      • 2 digital line-following sensors. Code your own line-following robots and race them to see whose code produces the fastest lap time!
      • 2 analog light sensors (front left and front right) so your Bit:Bot can be programmed to follow a light source such as a torch, or you could code it to go and hide in the darkest place it can find
      • Buzzer, so you can make beeping sounds whenever you want
      • Powered from integrated 3xAA battery holder with on/off switch and blue indicator LED
      • Easily plug your micro:bit in and out using the edge connector
      • Expansion connections at the front for additional sensors (ultrasonic rangefinder available now, more in development)
      Includes an ultrasonic distance sensor (rangefinder) module.
      Note: micro:bit is NOT included!
      Technical Details
      Dimensions188mm x 123mm x 24mm
      WeightG.W 151.5g
      BatteryExclude
      Driver Board (assembled motor)1
      wheel2
      bettery case1
      nuts4
      screws4
      Ultra Sonic range module1
      Omni-directional wheel kit1
      Reviews
      Questions and Answers
      SUBMIT
        View History
        SKU 114991414
        $49.95
        7 Available
        Maximum Qty: 5
        $49.95/1pcs+
        • Best-sellers
        • Description
        • Technical Details
        • Reviews
        • Questions and Answers
        • View History
        SUBMIT
        Invalid email address.
