BlinkyTape with USB Battery
SKU 104990068
BlinkyTape is a very special LED strip
$80.00
OUT OF STOCK
This item is not available at the moment
Get notified when it's back in stock
$80.00/1pcs+
$76.00/10pcs+
BlinkyTape is a very special LED strip. It has what we like to call an integrated light processor-- that means you don’t have to source your own microcontroller, power supply or connectors. Instead, you simply need to plug in to a wall charger or the included USB battery pack, and you’re good to blink.
BlinkyTape has 60 independently controllable full-color RGB LEDs, all wrapped up in a weather-resistant silicone case. All this is powered by that integrated light processor which has a standard micro-USB connector. This means you can connect it to the battery or another power supply to run on its own, or it can talk to a computer for interactive installations.
When you first plug in your BlinkyTape, you’ll be greeted by a colorful rainbow pattern. But the fun doesn’t stop there: the BlinkyTape comes with a full set of companion software to make it easy for you to make the patterns and effects you want. You can graphically draw patterns and animations the LED strip using PatternPaint. If dynamic lighting is more your style, check out our Processing tutorial -- it has a range of examples that allow you to create an LED light soundtrack to your favorite tunes, a backlight for your monitor, and more!
And best of all, we’re excited to see the amazing uses that members of our community create. BlinkyTape is going to keep getting better because of people like you!
This package also includes a long-lasting USB battery so you can blink on without being plugged in to mains power!
  • 60 independently controllable RGB LEDs (WS2812B)
  • Atmega 32u4 processor, compatible with Arduino
  • Animation storage space: 22K, enough for 300 frames (compressed)
  • Housed in waterproof silicon tubing (IP67)
  • 1 m (39”) long, 12.5mm (0.5") wide, 4mm (0.16") thick
  • LEDs spaced 16.5mm (0.65") apart
  • USB powered, 5V @ 300mA for a sample pattern (current draw varies with program)
  • Open source hardware and software.
  • Rechargeable 4400 mAh USB battery for powering your BlinkyTape
  • Battery weight:125g  dimensions:90mm*50mm*20mm
For more info and to get started with your BlinkyTape visit the start page. To join in the online discussion about BlinkyTape, visit the BlinkyTape forum.
If you encounter any problems when using this product, here is the contact from which you can get the technical support.
See More
$50 Featured List
$100 Featured List
$200 Featured List
Don’t miss out!
Questions and Answers
SUBMIT
See More
View History
Best-sellers
SUBMIT
Invalid email address.
