Bluetooth 4.0 Low Energy - BLE Mini
SKU 102990034
11.90
DISCONTINUED
You can now utilize Bluetooth 4.0 Low Energy (BLE) technology easily in your project with our BLE Mini. BLE Mini requires only a serial port for communication so it supports all major development platforms that have UART interface including Arduino, Raspberry Pi, Netduino, BeagleBone etc. In addition, we provide you with access to all Ti's CC2540 I/O pins and the ability to upload firmware via USB, making the BLE Mini an ideal development/protoyping board for your BLE project/accessory/Appcessory.
Requirement
  • An iPhone 5, iPhone 4S, iPad mini, iPad with Retina display (4th gen), iPad (3rd gen) or iPod touch (5th gen) plus our App from iTunes App Store. You could also develop your own iOS App using our open source SDK or iOS's CoreBluetooth Framework.
  • Or a second BLE Mini (require Central role support which will be available in March 2013)
  • Simple interface - with our pre-loaded firmware code name 'Biscuit', you could easily connect to any development board or IC with UART interface.
  • Compact form factor - this is a very popular request from makers using smaller Arduino boards like Arduino Mini/Micro/Nano/Pro Mini etc.
  • Support Central or Peripheral role - it can connect to other BLE Mini or BLE Shield, not just iOS device. (Central role support will be available in March 2013)
  • Standalone operation - Ti's CC2540 is a SoC (System-on-Chip) IC that can operate without any external microcontroller. You can develop your own firmware using IAR Embedded Workbench, all I/O pins of CC2540 are accessible.
  • Firmware upgradable - develop your own or download a "pre-packaged" firmware and upload to  BLE Mini via the USB connector, Ti CC Debugger is not required.
  • Provision for connection to external antenna.
Please visit RedBearLab for more info about this product and technical support.
Technical Details
Dimensions0mm x 0mm x 0mm
WeightG.W 15g
BatteryExclude
ECCNNot Available
HSCODE8517629900
Reviews
Questions and Answers
SUBMIT
0
Why there are only Apple devices in description? There are much more manufactures who have bluetooth 4.0 le implemented. Will that board work with them?
on Oct 19,2016
Reply upvote ()
I mean Nokia Lumia series mostly
on Oct 20,2016 10:48 AM
Reply upvote ()
Reply
0
Hi guys, does this require a PC to be discoverable? Can it be programmed to not require a PC by the end user?
on Oct 19,2016
Reply upvote ()
Hi Chris, this module without microcontroller, so it should be used with an microcontrollerboard(Arduino). PC is necessary for programming Arduino.
on Oct 20,2016 10:45 AM
Reply upvote ()
Reply
0
Works perfectly out of the box.
on Oct 19,2016
Reply upvote ()
0
How well does this board work with GROVE?
on Oct 19,2016
Reply upvote ()
Hello, GROVE in only a 4 pin interface with 2mm pin spacing, you could get a GROVE cable to connect it to GROVE base Shield.
on Oct 20,2016 10:44 AM
Reply upvote ()
Reply
    View History
    SKU 102990034
    $11.90
    DISCONTINUED
    $11.90/ 1pcs+
    • Description
    • Technical Details
    • Reviews
    • Questions and Answers
    SUBMIT
