the AI Hardware Partner
Toggle Nav
Loading...
CSR HM-11 Module
Bluetooth protocol: Bluetooth Specification V4.0 BLE Working frequency: 2.4 GHz ISM band Interface way: a serial port
$12.90
Out of stock
  • 10+: $8.90
This is a SMD BLE module used in our BLE Bee and Xadow BLE. It is based on TI cc2541 chip, enables robust network nodes to be built with low total bill-of-material costs and highly suited for ultralow power consumption systems. The module is small and easy to use, with the preprogrammed firmware of manufacturer, you can quickly build BLE communications via its AT command. Supporting BLE communications with iphone, ipad and Android 4.3.
  • Bluetooth protocol: Bluetooth Specification V4.0 BLE
  • Working frequency: 2.4 GHz ISM band
  • Interface way: a serial port
  • Open environment within 30 meters can realize communication between modules
  • To send and receive no byte limit between modules
  • Modulation method: GFSK (Gaussian Frequency Shift Keying)
  • Transmission power: - DBM, 23-6 DBM, 0 DBM, 6 DBM, can be modified by the AT command
  • Use TI CC2541 chip, configuration space of 256 KB, support the AT command, the user can according to need to change the role (master, slave mode) and the serial port baud rate, name of equipment, matching parameters such as passwords, use agile.
Dimensions 60mm x90mm x2mm
Weight G.W 1g
Battery Exclude
Power supply DC 3.3V
Communication protocol Uart(TTL)
Default baud rate 115200bps
Transmit current 15mA
Receive current 8.5mA
Deep sleep current 600uA
Operating temperature -40 ~ +65°C
Outline dimension 13.5 x 18.5 x 2.3mm
Bluetooth V4.0 HM-11 BLE Module 1
HSCODE 8517703000
USHSCODE 8517180050
UPC 841454115809
EUHSCODE 8517180000
COO CHINA
CE 1
FCC 1
RoHS 1
UK DoC 1
  1. Product Quality
    100%
    By
  2. Product Quality
    100%
    By
  3. Product Quality
    60%
    By
3 Item(s)
Show per page
