seeedstudio
      Items
      Total
      Go to Checkout
      Your cart is empty
      Bus Pirate v3.6 acrylic case v1 (DP6037)
      SKU 110990047
      $3.00
      25 Available
      $3.00/1pcs+
      $2.70/10pcs+
      ADD TO CART
      A clear laser-cut acrylic case kit for the Bus Pirate v3.6. This case is designed to be simple, cheap, and easy to assemble. The Bus Pirate PCB is sandwiched between two laser-cut acrylic sheets, and the whole assembly is held together with aluminum screws and standoffs.
      This is only compatible with Bus Pirate v3.6 that uses a DP6037 standard PCB template.
      If you encounter any problems when using this product, here is the forum from which you can get the technical support.
      Technical Details
      WeightG.W 26g
      BatteryExclude
      Reviews
      Questions and Answers
      SUBMIT
      1
      Is this case suitable for the Bus Pirate v3.8 ?
      on Oct 19,2016
      Replyupvote ()
      The 3.6 is exactly the same size as the BusPirate 3.8 so the case should fit fine. The only differences are the size of the LEDs, the USB socket, and the Header configuration. I finally realized I have BOTH versions so I could compare them... I'll be ordering 2 shortly.
      on Mar 10,2017 08:55 AM
      Replyupvote ()
      Reply
      0
      Does that fit the slightly older Bus Pirate 3.5c?
      on Oct 19,2016
      Replyupvote ()
      <p>Hi Harald, sorry that we are not familiar with Bus Pirate 3.5c, and we do not sell older Bus Pirate 3.5c before, so i can not try to find one to fit this case. While, i think you could compare the PCB layout between the two version Bus Pirate.</p>
      on Oct 20,2016 10:43 AM
      Replyupvote ()
      Reply
      0
      I'm not sure if the changes in version 4 are just in the chip, or also in the size. Thanks in advance.
      on Oct 19,2016
      Replyupvote ()
      <p>The size between V4 and V3.6 is different.So their laser-cut acrylic sheets are not the same size.</p>
      on Oct 20,2016 10:42 AM
      Replyupvote ()
      Reply
        View History
        SKU 110990047
        $3.00
        25 Available
        ADD TO CART
        $3.00/1pcs+
        $2.70/10pcs+
        • Best-sellers
        • Description
        • Technical Details
        • Reviews
        • Questions and Answers
        • View History
        SUBMIT
        Invalid email address.
