the AI Hardware Partner
Toggle Nav
Loading...
CH340G USB to Serial (TTL) Module&Adapter
It's a small USB to TTL serial tool, using the CH340G chip
$1.95
Out of stock
  • 10+: $1.76
It's a small USB to TTL serial tool, using the CH340G chip. You can use it to connect some serial device to your PC via USB port.
Features:
Compatible with 32-bit & 64-bit Windows, Mac OS 8 to OS X, Linux and Android!
To test the unit use the shunt to connect TX and RX (loopback test)
3.3V and 5.0V outputs are available to power your project directly from the adapter.
Part List:
1 x USB to TTL module
Dimensions 95mm x60mm x7mm
Weight G.W 6g
Battery Exclude
HSCODE 8517709000
USHSCODE 8517700000
UPC 841454115526
COO CHINA
RoHS 1
