CPT-C5 power converter 12V&24V switch to 5V
Rating:
50% of 100
Rating:
50% of 100
$8.50
In stock
20+ Available
Qty Discount available
  • $7.65 /10pcs+
  • $7.23 /20pcs+
CPT-C5 is a power converter module output 5V. Low heat, adopt synchronous rectification technology (5A long-term without any additional cooling measures).
  • Conversion efficiency of 96%.
  • Epoxy Glue, waterproof, shock, moisture, suitable for harsh environments.
  • Short circuit protection, over current, over temperature protection, when the fault is solve then back to work.
  • Ultra-small size 66 * 60 * 23mm(L * W * H, without cable), about 100 grams.
Applications Ideas
  • Solar power
  • Taxi advertising screen
  • LCD TV
  • Monitoring systems
Dimensions 0mm x0mm x0mm
Weight G.W 108g
Battery Exclude
Input voltage DC12/24V (8-35V)
Output voltage 5V
Output Power 25W
Soft-start time 500mS
Operating temperature Industrial (- 40 °C to +85°C )
Full load temperature 50 °C
Load Regulation ± 1%
Voltage regulation ± 2%
Dynamic response speed 5% 200uS
Input reverse polarity protection No, if necessary, add a series diode at input port
CPT-C5 power converter 12V&24V switch to 5V 1
ECCN ERA99
HSCODE 8504339000
Product Faqs
Sort by
