Clearance! Seeeduino Mega v1.1
SKU ARD131D2P
49.00
DISCONTINUED
This product is no longer for sale, it has been replaced with Seeeduino Mega.
Seeeduino Mega is a microntrolller board based on ATmega1280, derived from Arduino Mega with changes in pursuit for small form factor, flexibility and functionality.It has 70 digital input/output pins (of which 14 can be used as PWM outputs), 16 analog inputs, 4 UARTs (hardware serial ports), a 16 MHz crystal oscillator, a USB connection, a power jack, an ICSP header, and a reset button. It contains everything needed to support the microcontroller; simply connect it to a computer with a USB cable or power it with a AC-to-DC adapter or battery to get started. Seeeduino Mega is compatible with most shields designed for the Arduino Duemilanove or Diecimila, also share accessories with Seeeduino family.
Technical Details
Dimensions0mm x 0mm x 0mm
WeightG.W 25.30g
BatteryExclude
Reviews
Questions and Answers
SUBMIT
0
What is the different between the (no longer for sale) ARD131D2P and the $43 ARD121D2P which is still for sale?
on Oct 19,2016
Reply upvote ()
ARD121D2P is still sale and it just update, if you want to know more detail, search our WIKI, there are some description for what feature changed.
on Oct 20,2016 10:41 AM
Reply upvote ()
Reply
    View History
    SKU ARD131D2P
    $49.00
    DISCONTINUED
    $49.00/ 1pcs+
    • Description
    • Technical Details
    • Reviews
    • Questions and Answers
    SUBMIT
