the AI Hardware Partner
Toggle Nav
Loading...
Compass Module - .NET Gadgeteer Compatible
This product can now be purchased at www
$15.90
Out of stock
This product can now be purchased at www.ghielectronics.com.
Compass module for Gadgeteer. This module is designed for low field magnetic sensing with a I2C interface for applications such as compassing and magnetometry with 1°to 2°heading accuracy. It is suitable for applications like navigation system, consumer electronics.
Requires socket Type I.
  • Gadgeteer socket type I
  • 3-axis magneto-resistive type sensor
  • Up to 116 Hz maximum output rate
  • Built-in self test
External Links
you need to download the following software to start your Gadgeteer:
  1. Development tool : Microsoft Visual C# Express 2010
  2. Micro framework: Microsoft .NET Micro Framework 4.1 SDK
  3. The Gadgeteer core, mainboard SDk and module driver(GHI)
You can download these tools at : http://tinyclr.com/support
Dimensions 0mm x0mm x0mm
Weight G.W 5g
Battery Exclude
HSCODE 8529101000
