the AI Hardware Partner
Toggle Nav
Loading...
Copper Shaft Coupler(6-10mm)
These stainless copper shaft couplers allow you to couple the different size shafts together
$3.50
Out of stock
  • 10+: $3.15
  • 20+: $2.98
  • More
  • 50+: $2.80
  • Less
These stainless copper shaft couplers allow you to couple the different size shafts together. They can be used for connecting motor shafts to drive shafts, or two different sized shafts. The strength of the copper coupler is higher than aluminum coupler, Suitable for the bigger size shaft , All of they come with a hex wrench.
Specification:
Length: 22mm
Diameter: 15.7mm
Bore: 6-10mm
Weight: 25.0g
Dimensions 0mm x0mm x0mm
Weight G.W 28g
Battery Exclude
HSCODE 8483600090
