Crazyflie 2.0 Z-ranger deck board
SKU 114991072
17.00
14 Available
$17.00/ 1pcs+
The Z-ranger deck uses a laser sensor to measure the distance to the ground and adds the possibility to fly with precise height control. Using the ToF sensor VL53L0x the Crazyflie 2.0 can measure the distance from the sensor to a ground object at up two 2 meters.
  • Fast, accurate distance ranging
  • Measures absolute range up to 2 meters
  • Eye safe
  • VL53L0x ToF sensor to measure distance up to 2 meters within a few millimeters.
  • 1-wire memory for automatic expansion deck detection
Mechanical specifications
  • Weight: 1.6g
  • Size (WxHxD): 21x28x4mm
  • Designed for mounting under the Crazyflie 2.0
Compatibility
  • Works with the Crazyflie 2.0
Tech Support
If you have any further question for technical support, please contact support@bitcraze.io
Technical Details
Dimensions0mm x 0mm x 0mm
WeightG.W 1.60g
BatteryExclude
Z-ranger deck1
ECCNNot Available
HSCODE9031900090
Reviews
Questions and Answers
SUBMIT
    View History
    SKU 114991072
    $17.00
    14 Available
    $17.00/ 1pcs+
    • Description
    • Technical Details
    • Reviews
    • Questions and Answers
    SUBMIT
