the AI Hardware Partner
Toggle Nav
Loading...
Crazyflie 2.x Battery Charger with Spare Battery , Prolong The Flight of The Drone,Single-cell Li-Po battery based on MCP73832
Rating:
100 % of 100
Use the single-cell Li-Po 500mA battery charger always to have your 240mAh LiPo spare batteries fully charged to maximize your flight time of the Crazyfile2.x. If you’re a bit handy with a soldering iron you can even solder multiple chargers together for multi-battery charging.
$10.00
In stock
  • 500mA single-cell Li-Po battery charger: Maximize your flight time
  • Stable charge: Based on MCP73832 can enable stable protection of your charging
  • Charging indicator: Check the battery by charging indicator anytime and anywhere not through the drone
  • Connection points for chaining of multiple chargers: Multiple chargers can be connected by welding to realize multi-battery charging
It is possible to chain multiple chargers together to create a multi-battery charger. The P2 connectors on the chargers are simply soldered in parallel. If you’re a bit handy with a soldering iron you can even solder multiple chargers together for multi-battery charging.
Below are pictures of one possible setup. Don’t forget to check the rating of the connectors and make sure you use a power supply that can supply at least 500mA per charger.
Applications
Get the maximum flight time from your Crazyflie 2.x using this spare battery and charger.
The Crazyflie 2.1 is a versatile open-source flying development platform that only weighs 27g and fits in the palm of your hand.
  • The drone battery life
  • Quick charge
  • Backup power
Items
LiPo battery charger
Max charging current
500mA
Supply voltage
5V
Connector
micro-USB
Main chip
MCP73832
Connector point
1x2, 2.54mm pitch
Charging indicator
LED
Size (WxHxD)
10.5x16x1.6mm (not including cable)
Weight
1.2g
240mAh LiPo battery
Capacity
240mAh
Nominal voltage
3.7 V (1 Cell)
Discharge
15C
Operating Temperature
0 ~35°C (Charging) / -20~60°C (Discharging)
Connector
Molex 51005-2P (Pin 1 positive)
Weight
7.1g
Size (WxHxD)
20x7x30mm (not including cable)
Hardware Overview
Connect the battery charger to a standard micro USB connector and the battery connector to a battery. The LED is lit up while the battery is charging and turns off when fully charged.
Note
Using a battery under direct sunlight may cause overheating, which could result in invalidation or fire. Battery should be charged with proper charger, in compliance with correct operation instructions. Never charge a battery unattended!
×1
240mAh LiPo battery
×1
HSCODE 8504909090
USHSCODE 8471490000
EUHSCODE 8543709099
COO CHINA
RoHS 1
Documentations
  1. Documentation
    100%
    Product Quality
    100%
    from order view
    excellent product, works fine
    By
  2. Product Quality
    100%
    Documentation
    100%
    from order view
    This user did not leave any comments.
    By
2 Item(s)
Show per page
