Crazyradio PA - long range 2.4Ghz USB radio dongle with antenna
SKU 114990112
30.00
17 Available
$30.00/ 1pcs+
$27.00/ 10pcs+
Crazyradio PA is a long range open USB radio dongle based on thefrom Nordic Semiconductor. It features a 20dBm power amplifier, LNA and comes pre-programmed with Crazyflie compatible firmware. The power amplifier boosts the range, giving a range of more than 1km (line of sight) together with the Crazyflie 2.0 and above 2km Crazyradio PA to Crazyradio PA (line of sight).
The Crazyradio PA is not only for usage together with the Crazyflie and Crazyflie 2.0. Since it’s an open project with firmware written from scratch and a Python API for usage it’s great building block for systems that require longer range than WiFi and doesn’t have the same requirements for bandwidth. The hardware comes shipped with the latest firmware as well as a bootloader that enables firmware upgrades via USB without any additional hardware needed.
The Crazyflie PA is compatible with the first generation of the Crazyflie, but will not give the same range increase as with the Crazyflie 2.0.
  • Radio power amplifier giving 20dBm output power
  • 1km range LOS with Crazyflie 2.0
  • 2x5 2.54mm header for prototyping (not mounted)
  • Hardware support for PPM
  • Same mechanical footprint as the first generation Crazyradio
  • Open source firmware
  • Firmware upgrade via USB
  • Low latency
Specifications
  • Based on nRF24LU1+ chip from Nordic Semiconductor
  • 8051 MCU at up to 16MHz with 32Kb flash and 2Kb SRAM
  • 2.4GHz ISM band radio
  • USB device peripheral
  • 125 radio channels
  • 2Mbps, 1Mbps and 250Kps communication datarate
  • Sends and receives data packets of up to 32 bytes payload
  • Automatically handles addresses and packet ack
  • Hardware SPI and UART
  • Combatible with Enhanced ShockBurst protocol from Nordic Semiconductor
Radio Specification
  • 20dBm output power (100mW)
  • Low Noise Amplifier (LNA)
  • RPSMA connector
  • Can be powered with up to 13V via expansion header
  • 2x5 2.54mm expansion header with following signals (not mounted):
  • Hardware support for PPM input
  • Up to 13V input power
  • GND
  • PPM
  • SPI/UART
  • Standard USBA connector
Mechanical Specification
  • Weight: 6g
  • Size (WxHxD): 58x16x6.5mm (including connectors)
Tech Support
If you have any further question for technical support, please contact support@bitcraze.io
Technical Details
Dimensions0mm x 0mm x 0mm
WeightG.W 18g
BatteryExclude
long range 2.4Ghz USB radio dongle 1
antenna1
ECCNNot Available
HSCODE8517709000
Reviews
Questions and Answers
SUBMIT
0
Hello, can the Crazyradio PA - long range 2.4Ghz USB, handle multiple Crazyflie 2.0 drones at the same time?
on Aug 02,2017
Reply upvote ()
hi!Currently it's only used to communicate with the Crazyflie Nano Quadcopter but it can be adopted to work with a number of applications that are based on the low-cost 2.4 GHz chips from Nordic Semiconductor.
on Jan 09,2018 15:34 PM
Reply upvote ()
Reply
0
Does this module have certifications for FCC Part 15c ?
on Dec 15,2016
Reply upvote ()
Hello, I am sorry that this product is not under FCC compliant.
on Jan 16,2018 10:31 AM
Reply upvote ()
Reply
0
Hi, this product is compatible with DevDuino Sensor Node V3?
on Oct 19,2016
Reply upvote ()
HI Sorry,I'm afraid not
on Jan 31,2018 17:17 PM
Reply upvote ()
Reply
0
Will I be able to pair this with a receiver from a handheld radio, say an orangeRX receiver?
on Oct 19,2016
Reply upvote ()
Did you find any answer to your question? I am also looking forward to buy it and use it for my R/C Experimental Aircraft...
on Oct 20,2016 10:51 AM
Reply upvote ()
Reply
0
does this come with an antenna?
on Oct 19,2016
Reply upvote ()
Yes, it comes with a duck antenna.
on Oct 20,2016 10:49 AM
Reply upvote ()
Reply
    View History
    SKU 114990112
    $30.00
    17 Available
    $30.00/ 1pcs+
    $27.00/ 10pcs+
    • Description
    • Bundle sales
    • Technical Details
    • Reviews
    • Questions and Answers
    SUBMIT
