the AI Hardware Partner
Toggle Nav
Loading...
Cubietruck Kit - Dual Core Single-board Computer
Allwinner Tech A20 SOC SATA supported 54 extended pins SPDIF audio interface Suitable for student, software/hardware hackers
$94.90
Out of stock
  • 10+: $90.16
While A10/A20-cubieboard very suitable for student, software/hardware hackers, A20-cubietruck is suitable for us to make real product.
Cubietruck is the 3rd board of Cubieteam, we also name it Cubieboard3. It's a new PCB model adopted with Allwinner A20 main chip, the same with Cubieboard2. But it is enhanced with some features, such as 2GB memory, VGA display interface on-board, 1000M NIC, WIFI+BT on-board, support Li-battery and RTC, SPDIF audio interface.
FEATURES
  • Allwinner Tech A20 SOC
  • SATA supported
  • 54 extended pins
  • Built-in HDMI/ VGA display interface
  • Built-in WIFI+BT module
  • 2GB DDR3 RAM
  • Built-in IR receiver
  • SPDIF audio interface
SPECIFICATION
  • Allwinner Tech SOC A20 ARM Cortex -A7 Dual-Core ARM Mali400 MP2 Complies with OpenGL ES 2.0/1.1
  • 2GB DDR3@480MHz
  • HDMI&VGA 1080P display output on-board
  • 10M/100M/1G Ethernet
  • WIFI + BT wireless connection with antenna on-board
  • SATA 2.0 interface support 2.5’ HDD (for 3.5" HDD, only need another 12V power input)
  • Storage solution NAND + MicroSD
  • 2 x USB HOST, 1 x OTG, 1 x SPDIF, 1 x IR, 4 x LEDs, 1 x Headphone, 3 x Keys
  • Power [email protected] with HDD support Li-battery & RTC
  • 54 extended pins including I2S, I2C, SPI, CVBS, LRADC x2,UART, PS2, PWM x2, TS/CSI, IRDA, LINEIN&FMIN&MICIN, TVIN x4 with 2.0 pitch connectors
  • PCB size 11cm *8cm*1.4mm
  • Operating temperature: -10℃ ~ 70℃.
Cubieboard A10Cubieboard A20Cubietruck
Size 10cm x 6cm 10cm x 6cm 11cm x 8cm
CPU Cortex-A8 Cortex-A7 Dual-Core Cortex-A7 Dual-Core
CPU Clock Frequency 1GHz 1GHz 1GHz
RAM 1GB DDR3 1GB DDR3 2GB DDR3
Flash/NAND 4GB 4GB 8GB
WIFI/Bluetooth N/A N/A On-board
SATA SATA 2.0 SATA 2.0 SATA 2.0
RTC N/A N/A Li-battery and RTC on-Board
GPIO 96 extend pins 96 extend pins 54 extended pins
USB Host/OTG 2xUSB 2.0/ 1xMini USB 2.0 2xUSB 2.0/ 1xMini USB 2.0 2xUSB 2.0/1xMini USB 2.0
Video Out HDMI HDMI HDMI/VGA
Audio Out HDMI/ SPDIF/ Headphone HDMI/ SPDIF/ Headphone HDMI/ SPDIF/ Headphone
OS support Linux/Android Linux/Android Linux/Android
PART LIST
  • Cubietruck main board x1
  • SATA 2.0 cable x1
  • Mini USB to OTG x1
  • Mini USB cable x1
  • USB to 1.7 mm DC jack cable x1
  • Acrylic shell x1
  • Ultrathin Heat Sink x1
DOCUMENTS
Software
For more product information and technical support, please contact [email protected].
Dimensions 0mm x0mm x0mm
Weight G.W 451g
Battery Exclude
Documentations
  1. Product Quality
    80%
    By
1 Item
Show per page
