the AI Hardware Partner
Toggle Nav
Loading...
DSO nano - Pocket size digital storage oscilloscope
This product is discontinued, we have a new version DSO Nano v3 instead of DSO nano - Pocket size digital storage oscilloscope
$89.00
Out of stock
This product is discontinued, we have a new version DSO Nano v3 instead of DSO nano - Pocket size digital storage oscilloscope.
DSO nano is a pocket size digital storage oscilloscope fulfills basic electronic engineering requirements. It is base on ARM Cortex™-M3 compatible 32 bit platform, equipped with 320*240 color display, SD card capability, USB connection, and chargeable batteries. Weighs only 60g.
Features:
Display 2.8″ Color TFT LCD
Display Resolution 320×240
Display Color 65K
Analog bandwidth 0 - 1MHz
Max sample rate 1Msps 12Bits
Sample memory depth 4096 Point
Horizontal sensitivity 1uS/Div10S/Div (1-2-5 Step)
Horizontal position adjustable with indicator
Vertical sensitivity 10mV/Div10V/Div (with ×1 probe)
0.5V/Div100V/Div (with ×10 probe)
Vertical position adjustable with indicator
Input impedance >500KΩ
Max input voltage 80Vpp (by ×1 probe)
Coupling DC
Trig modes Auto, Norma, Single, None and Scan
Functionalities: Automatic measurement: frequency, cycle, duty, Vpp, Vram, Vavg and DC voltage
Precise vertical measurement with markers
Precise horizontal measurement with markers
Rising/falling edge trigger
Trig level adjustable with indicator
Trig sensitivity adjustable with indicator
Hold/run feature
Test signal Built-in 10Hz1MHz (1-2-5 Step)
Waveform storage SD card
PC connection via USB as SD card reader
Upgrade by bootloader via USB
Power supply 3.7V Chargeable Lithium battery / USB
Dimension (w/o probe) 105mm X 53mm X 8mm
Document:
Package list:
  • DSO nano body x 1
  • 3.7v lithium battery with connector x 1
  • Back plate x 1
  • Mini Probe x 1
  • Manual X1
  • Protection bag X1
Resources:
You can also have a nice stand for your DSO nano here.
Dimensions 0mm x0mm x0mm
Weight G.W 180g
Battery Exclude
