Desktop Mini Lathe
Product Feature: Mini Metal(Non-ferrous) lathe power of motor: 400W; Spindle speed 0-2500RPM Infinitely variable. Metal lathe machine using four-way rotating turret, which can be four common turning.
$699.00
Out of stock
If you would like to purchase or obtain more information about this item, please email us at: Manufacturing@chaihuo.org
•  Mini Metal (Non-ferrous) lathe power of motor: 400W; Spindle speed 0-2500RPM Infinitely variable. Metal lathe machine using four-way rotating turret, which can be four common turning. Multi-function and multi stage, can be turned within foreign aid, turning thread, turning taper and so on.
•  This precision mini lathe is designed to perform various types of metal turning. This machine can be used in areas such as mini precision parts processing, sample processing and modeling works
Standard Features:
•  Safety switch
•  Variable speed control
•  Four position turret post
•  Complete set of change gear
•  High accuracy
•  Clear guard on spindle
TECHNICAL PARAMETERS
Process exact
0.02mm
Swing over bed
180mm
Distance between centers
300mm
Hole throughspindle
20mm
Spindle taper
MT#3
Tailstock taper
MT#2
Spindle speed
Low range:0-1100rpm
High range:0-2500rpm
Output power
400w
Range of threads
Metric:0.5-2.5mm(10thread pitches)
Imperial:12-52TPI(8 thread pitches)
Net/Gross weight
38/42 kg
Packing size
760x305x315 mm
Product Faqs
Sort by
