the AI Hardware Partner
Toggle Nav
Loading...
Desktop Mini Milling Machine
Drill, mill and cut slots, grooves and small parts with this powerful mini milling machine and is affordable for everyone!
$699.00
Out of stock
If you would like to purchase or obtain more information about this item, please email us at: [email protected]
•  Drill, mill and cut slots, grooves and small parts with this powerful mini milling machine and is affordable for everyone! No belt changes necessary. The variable speed control and gear drive can save you time and leaves you with hassle-free, truly a remarkable machine.
Standard Features:
•  Safety switch
•  Variable speed control
•  Four position turret post
•  Complete set of change gear
•  High accuracy
•  Clear guard on spindle
TECHNICAL PARAMETERS
Process exact
0.02mm
Drilling capacity
16mm
End milling capacity
13mm
Face milling capacity
25mm
Headstock travel(Z)
220mm
Cross axis(X)
300mm
Longitudinal axis(Y)...
130mm
Spindle rotary angle
-45°~ +45°
Output power
550w
Spindle speed
Low range:50-1100rpm
High range:120-2500rpm
Spindle taper
MT#3
T-slot
12mm
Net/Gross weight
62/80kg
Packing size
640×565×760mm
