Digital RGB LED Flexi-Strip 30 LED - 1 Meter
SKU 104990000
9.90
15 Available
$9.90/ 1pcs+
$8.91/ 10pcs+
Digital RGB LED Flexi-Strip is an intelligent light source consist s of WS2812B RGB LED with Integrated Driver Chip. The control circuit and RGB chip are integrated in a package of 5050 components.
This LED flexible strip is a full-color that external control for each lamp beads. It with high brightness, can achieve effects of full color running water, chasing and scan.
The RGB LED chips with low driving voltage, environmental protection and energy saving, high brightness, scattering angle is large, good consistency, low power, long life and other advantages. The control chip integrated in LED above becoming more simple circuit, small volume, convenient installation.
  • Integrating control circuit and RGB chip
  • Built-in signal reshaping circuit
  • Built-in electric rest circuit and power lost reset circuit
  • 256 brightness and 16777216 color display
  • Cascading port transmission signal
Specifications
  • Working voltage: DC 5V
  • Max. power rate: 0.3W/LED
  • Working temperature: -40℃~60℃
  • LED number: 30pcs/meter
  • Viewing angle: ≥140
  • Lifespan: MTBF≥50000h
Documents
Technical Details
Dimensions80mm x 80mm x 10mm
WeightG.W 12g
BatteryExclude
ECCNERA99
HSCODE9405409000
Certification
RoHSCompliant
Reviews
Questions and Answers
SUBMIT
0
The link to the simple circuit is dead
on Nov 28,2016
Reply upvote ()
Hi, It works now~
on Feb 09,2018 11:06 AM
Reply upvote ()
Reply
0
How do you connect this to the Wio as the cable doesn't have a grove connector.
on Jan 25,2017
Reply upvote ()
Hi, I am sorry for there is no any grove connetors , but wire jumper works.
on Feb 09,2018 11:05 AM
Reply upvote ()
Reply
    View History
    SKU 104990000
    $9.90
    15 Available
    $9.90/ 1pcs+
    $8.91/ 10pcs+
    • Description
    • Technical Details
    • Reviews
    • Questions and Answers
    SUBMIT
