the AI Hardware Partner
Toggle Nav
Loading...
Driver Breakout for micro:bit, drives motors and servos
Driver Breakout for micro:bit, drives motors and servos,micro: bit,Driver Breakout,drive 2 DC motots and 3 steering gears,Comes with developing resources and munual
$11.90
Out of stock
  • 10+: $11.40
This driver board gives your micro:bit the ability to drive two channel DC motors and three channel servos. It's an ideal choice for you to DIY mobile robots.
  • micro:bit edge connector, directly pluggable
  • 2x DC motor interfaces, 3x servo interfaces
  • Integrates 5V regulator, up to 3A output current, can be powered from battery through VIN terminal
  • Onboard multi connector options for DC motors in different specifications, onboard standard servo headers
  • Comes with development resources and manual (micro:bit graphical examples)
Micor:bit has variety of programming methods like mbed, micropython, typescript and other programming methods, as well as code online websites which are abundant.
The official recommendation are two programming methods: typescript and micropython. Typescript is the graphical programming language. Its website is that: https://makecode.microbit.org/#
Dimensions 15mm x65mm x36mm
Weight G.W 0.219g
Battery Exclude
Power supply 6V~12V (VIN terminal)
Servo voltage 5V
Logic voltage 3.3V
Driver TB6612FNG
Mounting hole size 3.0mm
Vcc Power (6~12V)
GND Ground
A1 positive pole of motor A
A2 negative pole of motor A
B1 positive pole of motor B
B2 negative pole of motor B
P0 control pin P0 of steering gear
P1 control pin P1 of steering gear
P2 control pin P2 of steering gear
Motor Driver for micro:bit 1
HSCODE 8503001000
USHSCODE 8543708900
UPC
EUHSCODE 8471707000
COO CHINA
RoHS 1
