EL Panel - Red 10cm x 10cm
  • EL Panel - Red 10cm x 10cm
SKU 104990047
A big sister to our EL tape, the EL panel is a similar item that comes in a 10 cm square format
$8.90
2 Available
Qty:
This field is required
ADD TO CART
$8.90/1pcs+
$8.01/10pcs+
$7.57/20pcs+
$7.12/50pcs+
A big sister to our EL tape, the EL panel is a similar item that comes in a 10 cm square format.  You’ll notice when working with it that it shares some of the same features as the EL tape:  flexibility, portability, and a beautiful soft glow.  It can be used as backlight for an illuminated device, or a platform for paper-cutting artwork.  Post it on a flat surface or wrap it around a curved surface.  Use it in a project as a lighting element or attach it to a shirt.  The options are amazing.
You need an inverter to drive the EL light, to control it, please pick up an EL Shield.
  • No heat loss
  • Great backlight material
  • High efficiency (97%)
  • Does not emit UV light
  • Soft light that is not harsh on the eyes
  • Waterproof, except the connecter
  • The higher voltage EL USB inverter is recommended because it produces a stronger light
  • Able to be cut into other shape
Specifications
  • Dimension:  10 cm x 10 cm
  • Thickness:  0.4 mm - 1.0 mm
  • Operating Voltage:  100 V~ 220 V  Optimum :  120 V
  • Operating Frequency:  50 Hz~ 5000 Hz   Optimum:  1500 Hz - 2000 Hz
  • Static Capacitance:  6 nf/m (20 ° C, the RH <80%)
  • Brightness:   30 cd/m2 ~ 126 cd/m2 (at 120 V, 200 Hz ~ 2000 Hz)
  • Power:  108 mw m ~ 1032 mw/m (at 120 V, 200 Hz ~ 2000 Hz)
  • Life:  approximately 8000 hours
  • Operating Temperature/Humidity:  -10 °C ~ + 60 °C/RH < 90%
  • Storage Temperature/Humidity:  -10 °C ~ + 60 °C/RH < 65%
See More
$50 Featured List
$100 Featured List
$200 Featured List
Don’t miss out!
Questions and Answers
SUBMIT
0
How many nm ?
on Oct 19,2016
Replyupvote ()
Hello.Please forgive my poor comprehension.Could you show your question more detailed.Thanks.
on Oct 20,2016 10:43 AM
Replyupvote ()
Reply
0
Can i directly connect this panel to my wall outlet with 220v 50hz?
on Oct 19,2016
Replyupvote ()
Hi.yes you can,but the operational voltage Less than 220v is more better.
on Oct 20,2016 10:44 AM
Replyupvote ()
Reply
0
hi, it's works with El USB that in input 5V - 500mh?
on Oct 19,2016
Replyupvote ()
Hi,Dear.Yes,it is.
Replyupvote ()
Reply
See More
View History
Best-sellers
SUBMIT
Invalid email address.
