EL Tape - white 1.5m
  • EL Tape - white 1.5m
SKU TEM04122B
Please read through the guide in Shenzhen 2 U before making any purchase in this catalogue
Free Express Shipping on Orders over $200!
$7.90
DISCONTINUED
This bright and long-lasting EL Tape strip measures 1.5 meters long, and it is very easy to use.  A connector is attached to one end, and there is an adhesive on the back side, so that you can stick the tape to any surface that your heart desires.
  • Cool to the touch, flexible in length.
  • Bendable, and able to tie into any shape.
  • You can cut it to any length you want.
  • Easy to use.
  • Low power consumption (cold light, electricity 97% converted to light, no heat loss), no UV, soft light, green products.
  • Waterproof, but the connecter attached is not waterproof.
  • We strongly suggest you use it with our El tape USB inverter.
Specifications
  • Length : 1.5m
  • Width :  15mm(This accounts for the entire width of the plastic coating.)
  • Thickness:  0.4mm-1.0mm
  • Operating Voltage:  100 ~ 220V
  • Optimum Operating Voltage:  120V
  • Operating Frequency:  50 ~ 5000Hz
  • Optimum Operating Frequency:  1500-2000Hz
  • Static Capacitance:  6nf / m (20 ° C, the RH <80%)
  • Brightness:  (At 120V, 200Hz ~ 2000Hz) 30cd/m2 ~ 126cd/m2
  • Power:  (At 120V, 200Hz ~ 2000Hz) 108mw m ~ 1032mw/m
  • Light life:  (At 100V, 400Hz) normal temperature and humidity, approximately 8000 hours
  • Operating Temperature/Humidity:  -10°C ~ +60°C; RH <90%
  • Storage Temperature/Humidity:  -10°C ~ +60°C; RH <65%
See More
$50 Featured List
$100 Featured List
$200 Featured List
Don’t miss out!
Reviews
See More
Questions and Answers
SUBMIT
See More
View History
Best-sellers
SUBMIT
Invalid email address.
