EL Tape - blue 1.5m
EL Tape - blue 1.5m
SKU TEM04121B
7.90
DISCONTINUED
This bright and long-lasting EL Tape strip measures 1.5 meters long, and it is very easy to use.  A connector is attached to one end, and there is an adhesive on the back side, so that you can stick the tape to any surface that your heart desires.
  • Cool to the touch, flexible in length.
  • Bendable, and able to tie into any shape.
  • You can cut it to any length you want.
  • Easy to use.
  • Low power consumption (cold light, electricity 97% converted to light, no heat loss), no UV, soft light, green products.
  • Waterproof, but the connecter attached is not waterproof.
  • We strongly suggest you use it with our El tape USB inverter.
Specifications
  • Length : 1.5m
  • Width :  15mm(This accounts for the entire width of the plastic coating.)
  • Thickness:  0.4mm-1.0mm
  • Operating Voltage:  100 ~ 220V
  • Optimum Operating Voltage:  120V
  • Operating Frequency:  50 ~ 5000Hz
  • Optimum Operating Frequency:  1500-2000Hz
  • Static Capacitance:  6nf / m (20 ° C, the RH <80%)
  • Brightness:  (At 120V, 200Hz ~ 2000Hz) 30cd/m2 ~ 126cd/m2
  • Power:  (At 120V, 200Hz ~ 2000Hz) 108mw m ~ 1032mw/m
  • Light life:  (At 100V, 400Hz) normal temperature and humidity, approximately 8000 hours
  • Operating Temperature/Humidity:  -10°C ~ +60°C; RH <90%
  • Storage Temperature/Humidity:  -10°C ~ +60°C; RH <65%
Technical Details
Dimensions0mm x 0mm x 0mm
WeightG.W 33g
BatteryExclude
Reviews
Questions and Answers
SUBMIT
0
I want to buy 20 Meters in green Color.
on Oct 19,2016
Reply upvote ()
Hi there, good to know you interesting our product. If you like Green color, please go to our WISH page to post you require and we would stock it.
on Oct 20,2016 10:41 AM
Reply upvote ()
Reply
    View History
    EL Tape - blue 1.5m
    SKU TEM04121B
    $7.90
    DISCONTINUED
    $7.90/ 1pcs+
    • Description
    • Technical Details
    • Reviews
    • Questions and Answers
    SUBMIT
