Go to Checkout
      Your cart is empty
      EL Tape - white 1.5m
      • EL Tape - white 1.5m
      SKU TEM04122B
      Please read through the guide in Shenzhen 2 U before making any purchase in this catalogue
      This bright and long-lasting EL Tape strip measures 1.5 meters long, and it is very easy to use.  A connector is attached to one end, and there is an adhesive on the back side, so that you can stick the tape to any surface that your heart desires.
      • Cool to the touch, flexible in length.
      • Bendable, and able to tie into any shape.
      • You can cut it to any length you want.
      • Easy to use.
      • Low power consumption (cold light, electricity 97% converted to light, no heat loss), no UV, soft light, green products.
      • Waterproof, but the connecter attached is not waterproof.
      • We strongly suggest you use it with our El tape USB inverter.
      • Length : 1.5m
      • Width :  15mm(This accounts for the entire width of the plastic coating.)
      • Thickness:  0.4mm-1.0mm
      • Operating Voltage:  100 ~ 220V
      • Optimum Operating Voltage:  120V
      • Operating Frequency:  50 ~ 5000Hz
      • Optimum Operating Frequency:  1500-2000Hz
      • Static Capacitance:  6nf / m (20 ° C, the RH <80%)
      • Brightness:  (At 120V, 200Hz ~ 2000Hz) 30cd/m2 ~ 126cd/m2
      • Power:  (At 120V, 200Hz ~ 2000Hz) 108mw m ~ 1032mw/m
      • Light life:  (At 100V, 400Hz) normal temperature and humidity, approximately 8000 hours
      • Operating Temperature/Humidity:  -10°C ~ +60°C; RH <90%
      • Storage Temperature/Humidity:  -10°C ~ +60°C; RH <65%
      See More
      $50 Featured List
      $100 Featured List
      $200 Featured List
      Don’t miss out!
      See More
      Questions and Answers
      See More
      View History
      Invalid email address.
