Special Price $6.90 Regular Price $9.95
In stock
60+ Available
EMW3080 is a cost-effective embedded Wi-Fi module released by MXCHIP with high integrating ARM CM4F, WLAN MAC/Baseband/RF. Maximum frequency 133MHz with 256KB SRAM and 2M FLASH. Power supply is DC 3.3V. Installation modes are LGA SMT and Pin Connection. Peripheral: 2xUART / 1x SPI /2x I2C / 6x PWM / Up to 13 GPIOs. EMW3080 operates MiCO 3.0 IoT operating system, supporting Micoder 1.0 development system. Provide fast, stable and secure end-to-end cloud links to users with integrate TCP/IP protocol stack, various security encryption algorithm, intelligent cloud such as MXCHIP easylink/Alink 1.1/Joinlink 3.0/Hilink/One Net/Gome/Suning, oversea cloud such as AWS/Ayla/Azure/IBM Watson/Google/Apple Homekit. EMW3080 (B): Abundant peripherals and memory to supply most application and multi-cloud requirement.
Application scenarios
Intelligent Security
Industrial automation
Smart Home Application
Intelligent Transportation
Intelligent lighting
Properties
  • Support 802.11b/g/n, integrate ARM-CM4F, WLAN MAC/Baseband/RF
  • 256KB RAM/ 2MB FLASH
  • Working Voltage: DC 3.0-3.6V
  • Maximum transmission rate up to 72.2 Mbps with 20 MHz bandwidth.
  • Maximum transmission rate up to 150 Mbps with 40 MHz bandwidth.
  • EMW3080B is standard module;EMW3080A has hardware encryption. Improve the security level of Cloud connection and firmware protection. Security level in accordance with CC EAL5+ AVA_VAN5
  • EMW3080(A) Hardware Encryption Features
  • Encrypt firmware of clients to prevent cracking
  • Digital signature is used in firmware to ensure integrity and legality, preventing being tampering or replaced in OTA.
  • Automatically generate private key to save the certificate issued from the cloud, the cloud can identify the legality of the device to prevent illegal, counterfeit, non-secure accessing.
  • Prevent hackers to obtain sensitive data and code
Wi-Fi Features
  • Support 802.11b/g/n,HT-40
  • Support Station, Soft AP, Station+Soft AP
  • Support EasyLink,Alink,Joinlink
  • Antenna: IPX
Peripherals
  • 2x UART
  • 2x I2C
  • 1x SPI
  • 1x SWD
  • 6x PWM
  • Up to 13GPIOs
Operating Temperature
  • -20℃ to +85℃
Dimensions 0mm x0mm x0mm
Weight G.W 4g
Battery Exclude
EMW3080(BE) WiFi Module 1
ECCN 5A002.a
HSCODE 8517709000
USHSCODE 8517700000
Product Faqs
Sort by
