the AI Hardware Partner
Toggle Nav
Loading...
Elastic Coupling(5-8mm)
These Aluminum shaft couplers allow you to couple two size shafts together
$2.75
Out of stock
These Aluminum shaft couplers allow you to couple two size shafts together. They can be used for connecting motor shafts to drive shafts, or two different-sized shafts. One-piece design allows flexible coupling to achieve a zero clearance to transmit torque and no maintenance advantages. Flexible coupling is the preferred product, In many stepper, servo system, Practical applications.
Specification:
  • Length:24.5mm
  • Diameter: 19mm
  • Bore A: 5mm
  • Bore B: 8mm
Part List:
  • 1 x Aluminum shaft couplers
  • 4 x Net
  • 1 x Allen driver
Dimensions 0mm x0mm x0mm
Weight G.W 15g
Battery Exclude
HSCODE 8483600090
ROHS 1
