the AI Hardware Partner
Toggle Nav
Loading...
Electronic brick - 125Khz RFID Card Reader
Seeed 125K RFID reader is a module used to read uem4100 RFID card information with two output formats: Uart and Wiegand
$13.50
Out of stock
Seeed 125K RFID reader is a module used to read uem4100 RFID card information with two output formats: Uart and Wiegand. It has high sensitivity with maximum 7cm sensing distance. The 4pins of Electronic Brick Interface make it be very easily used with Arduino or Seeeduino.
  • Selectable output format : Uart or Wiegand
  • 4Pins Electronic Brick Interface
  • High Sensitivity
Key specifications
  • Supply voltage: 5v
  • Max sensing distance: 7cm
  • Uart output: TTL output, 9600baudrate, 8 data bits, 1 stop bit, and no verify bit.
  • Wiegand output: 26 bits wiegand format, 1 even verify bit, 24 data bits, and 1 odd verify bit
Documents
Please visit our wiki page for more info about this product. It will be appreciated if  you can help us improve the documents, add more demo code or tutorials. For technical support, please post your questions to our forum.
Dimensions 0mm x0mm x0mm
Weight G.W 10g
Battery Exclude
