Electronic brick - Starter kit
  • Electronic brick - Starter kit
SKU ELB138E1P
This is a Starter kit of electronic brick; it includes basic components and sensors
$49.00
DISCONTINUED
This is a Starter kit of electronic brick; it includes basic components and sensors. You can build many interesting projects even if you don't know anything about soldering that makes it the best choice for beginners.
Parts list
  • Arduino/Seeeduino sensor Chassis V1.1 X1
  • LCD 16*2 Characters X1
  • Rotary angle sensor (Analog) X1
  • Big button switch X1
  • Buzzer X1
  • Tilt switch X1
  • Lighting emitting diode X2
  • Light sensor X1
  • Temperature sensor X1
  • 2pin pluggable terminal module X1
  • Fully buckled 3 wire cable X5
  • 10 pin colorful ribbon cable with 2*5 IDC connector X1
Documents
Please visit our wiki page for more info about this product. It will be appreciated if  you can help us improve the documents, add more demo code or tutorials. For technical support, please post your questions to ourforum.
See More
$50 Featured List
$100 Featured List
$200 Featured List
Don’t miss out!
Questions and Answers
SUBMIT
0
If this product is discontinued, which product do you recommend to replace it? Maybe"Grove - Starter Kit for Arduino"? Is it a direct replacement? Thanks
on Oct 19,2016
Replyupvote ()
EEEEEEEIIII!!!!!
on Oct 20,2016 10:50 AM
Replyupvote ()
Reply
0
hy, i am using the temperature sensor in a project at my university. I need to know the accuracy of the temperature sensor but I can't find it anywhere. Can you please tell me the accuracy of the sensor?
You can contact me at m.g.001@web.de
on Oct 19,2016
Replyupvote ()
The temperature sensor Grove uses a thermistor which returns the ambient temperature in the form of a resistance value, which is then used to alter Vcc (5V with our Seeeduinos). Our board then converts this voltage value measured by an analog input pin
on Oct 20,2016 10:46 AM
Replyupvote ()
Hi the solar charger shield can not charge iphone or ipad. The lipo rider is able, but it only support charging for iphone becasue the ipad need more current in above 1.5A.
on Oct 20,2016 10:48 AM
Replyupvote ()
Reply
0
I have purchased the kit, it works great to me. However, I got data from the temperature sensor, how can I translate it to degree?
where can I find the code?
Thanks!!
on Oct 19,2016
Replyupvote ()
Hi, thanks for the information. However I copy the code to my patch, the LCD indicator show the temperature between 4-7 degrees, but I was staying indoor, it should be between 20- 25 degree instead.
on Oct 20,2016 10:43 AM
Replyupvote ()
Reply
0
My review of Electronic Bricks can be found here: http://bit.ly/cAxdis
on Oct 19,2016
Replyupvote ()
0
I liked this a lot, easy to use and fun. Wrote a review at my blog, check it out: http://tronixstuff.wordpress.c...
on Oct 19,2016
Replyupvote ()
Yes,you can.
on Oct 20,2016 10:44 AM
Replyupvote ()
Reply
See More
View History
Best-sellers
SUBMIT
Invalid email address.
