Electronic brick - 2pin plugable terminal module(AD)
  • Electronic brick - 2pin plugable terminal module(AD)
SKU 320110081
This brick is a simple plugable terminal module, you can easily plug some other stuff into this without connect the wire to the terminal every time
$2.90
DISCONTINUED
This brick is a simple plugable terminal module, you can easily plug some other stuff into this without connect the wire to the terminal every time.
Electronic Bricks?
Yes! We can build electronics projects just as easy as piling bricks. Arduino and community have made the programming much easier than ever before. How about some elixir on hardware part? Maybe it is not yet convenient to make complex interfaces, but we can at least start from the most commonly used modules.
By using electronic bricks, you may connect Arduino compatible boards easily with various digital, analog and I2C/Uart interfaces. These the breadboard-less firm connection are prepared to extensive modules like poteniometers, sensors, relays, servos...even buttons, just plug and play.
Each terminal module has buckled port with VCC, GND and Output, which has corresponding port on the sensing board, with a plain 2.54mm dual-female cable you may start playing already. Buckled brick cables are like cement for bricks, make the connections easier, secure and more professional looking.
Note:These bricks are working with Arduino sensor shield
See More
$50 Featured List
$100 Featured List
$200 Featured List
Don’t miss out!
Questions and Answers
SUBMIT
See More
View History
Best-sellers
SUBMIT
Invalid email address.
